Results 1 to 5 of 5
Thread: f/s sony xplod amp
    rockin' the double M's
    l'ville,ga
    Default f/s sony xplod amp
    used 6 months works perfect. $80 obo
    great for 2 10's or 1 12
    Description:
    600W max power
    100W x 2 RMS into 4 ohms, 20Hz - 20kHz @ 0.08% THD
    250W x 1 RMS into 4 ohms, 20Hz - 20kHz @ 0.1% THD
    Class A/B
    Variable 50-300Hz low pass filter
    40Hz EQ boost
    Line level through-put
    MOSFET power supply
    RCA & speaker level inputs
    Specification --
    Circuit system -- OTL (output transformerless) circuit
    Power supply -- Pulse
    Maximum outputs -- 200 W x 2 (at 4 ohms)
    Maximum outputs -- 275 W x 2 (at 2 ohms)
    Maximum outputs -- 550 W (monaural) at 4 ohms
    Rated outputs (at 14.4V) -- 100 W x 2 (20 - 20kHz, 0.04% THD, at 4 ohms)
    Rated outputs (at 14.4V) -- 125 W x 2 (20 - 20 kHz, 0.1% THD, at 2 ohms)
    Rated outputs (at 14.4V) -- 250 W (monaural) (20 - 20 kHz, 0.1% THD, at 4 ohms)
    Frequency response -- 5 Hz - 50 kHz (?3dB)
    Harmonic distortion -- 0.008% or less (at 1 kHz, 4 ohms)
    Input level adjustment range -- 0.2 - 6V (RCA pin jacks), 1.2 - 12V (High level)
    Low-pass filter -- 50 - 300 Hz, -12 dB/oct
    Low boost -- 0 - 10 dB (40 Hz)
    Inputs -- RCA pin jacks, High level input connector
    Outputs -- Speaker terminals, Through output pin jacks
    Speaker impedance -- 2 - 8 ohms (stereo)
    Speaker impedance -- 4 - 8 ohms (when used as a bridging amplifier)
    Power requirements -- 12 V DC car battery (negative ground)
    Power supply voltage -- 10.5 - 16 V
    Current drain -- 25 A (at 4 ohms, rated output)
    Approximate measurments -- 12-1/8" x 2-1/4" x 7-7/8" (wxhxd) not including projecting parts and controls
    Weight -- Approx. 2.7 kg (6 lb)
    Dimensions -- Approx. 307 x 55 x 200mm
    Attached Thumbnails Attached Thumbnails -4sale-002-jpg
    l'ville,ga
    o bumpi wan kenobi
    l'ville,ga
    $70? bump
    Fuk Who U B!
    Northside B
    50 bucks in Hand let me know !
    Certified Gearhead civicracer5000's Avatar
    atlanta
    i give you $55
