Results 1 to 2 of 2
Thread: FS: 93 Protege LX
    ALL CAPS JITB's Avatar
    Default FS: 93 Protege LX
    Over the last couple of months, i have lost all enthusiasm, and kind of gotten tired of the good ole pro. So this time im seriously gonna sell it. And try to get a p5.. :thumb:
    93 LX Teal
    1.8DOHC
    112k
    5speed
    aluminum wheels
    Power Windows
    Power Sunroof
    New piston rings @90k
    New Timing Belt @90k
    New Radiator Fan (huge)
    New triple layered copper headgasket @90k (replaced before original went)
    New Starter (last month)
    Reman Distributor
    New Fuel Pump (2 months ago)
    New Fuel Filter
    Clutch was replaced before i bought the car when it had 75k..with a exedy clutch.
    New battery (2 months)
    Reman Clutch master/slave Cylinder
    New Distributor cap/rotor button
    New Denso Plugs
    175-Yokohama tires - Front 165-Kumho -front
    NO P/s - NO A/c Compeltely removed, Stil have the Power steering setup to be reinstalled.
    Extras:
    Pacesetter Header (flexpipe installed)
    Test pipe
    Apexi lookalike muffler
    Cone Filter
    ST Coilovers
    MX3 rear Tie Bar
    Mx3 seats
    Mx3 steering wheel
    Accel Coilpack
    Denso Plugs
    Trunk Mouned Battery
    Aiwa CD pLayer
    626 front lip
    New speakers all around
    Painted wheels
    Escort GT Glass Sunroof and sliding shroud
    Pilot Foglights
    Escort GT Foglight switch
    More little extras..
    I have a pieced together Turbo Setup , most of everything Manifold - pipes - BOV - FPR - Etc. just need antoher Turbo/downpipe/intercooler, taht will go with the car.
    BAD:
    Dent on driver side fender, from a accident last year..fender needs to be replaced in order for the corner lense to sit flush..but most of the damage to the fneder is internal and is hidden byt he headlight. I think i have hidden it very ver well..
    Core support, was damaged a bit...as well, but not noticeble until its pointed out.
    Inner Axle boots are busted..hasnt started to click yet..so they may be able to be saved...
    Paint is showing its age..12yr old paint can onlylast soo long....its not horrible, but its a little ashy on the top.
    thats about it...everything else is superb!
    Im looking for ATLEAST...2000$ - 2500$ enough to give me a decent downpayment on a P5.
    Phone: 404-202-4361
    Aim: jitb37
    email: [email protected]
    pics from accident lst year:
    Info on proteges BG chassis:
    Same chassis as the Mx3 - Escort GT - Kia Sephia - 323
    Protege is lighter than the Mx3, by maybe 200lbs, but heavier than the EscortGT. 323 is the lightest of them all.
    Swaps?? Yes
    BPT - GTX 1.8Turbo 180hp
    BPT - GTR 1.8 Turbo 210hp
    KLZE V6 190hp
    KLDE V6 - 170hp
    all thos motors go in with little to no hassle,,the most you will need is a tranny/crossmember for the v6's. but its like dropping a ls in a hatch. The motor in the car now is the same block as the JDM-Euro versions of the motor. It has the oil/coolant lines already taped in it. ready for boost..this motor is no NA motor. Its made for turbo, and if u wanted to build it for NA..it will be a huge money pit, but its a possibility. Forged crank - rods are oem and are equiped. iron block, aluminum head. with only 8psi u will easily have 13's, and push 190+. Differences in the GTX/GTR and the NA 1.8, are just the head(less restrictive for na purposes) - rods are stronger lower comp in the gtx. The GTR has a bigger turbo..VJ23, instead of the VJ20 ihi turbo.
