The radiator is for a DENSO application. It is your responsibility to make sure the radiator will fit your car.
This is basically a brand new radiator. Once I installed it, I realized I had to make some adjustments to make it fit. I didn't want to go through all that. I sold the GSR and the radiator has been sitting for a few months. It was installed for 30 minutes. Unfortunately, as I was removing the rad I caused a small leak. I had it repaired at a local radiator shop for $80. You can see the repair in the pics. I had a KOYO rad cap but sold it recently. I will throw in a Stant 13psi cap, but you may want to get a higher rated cap down the road.
The asking price is $250. It was purchased for $350. The low price is due to some bent fins, which you can actually repair yourself. The radiator will be sold in its original packaging.
