Results 1 to 11 of 11
Thread: code 71, 72
    Default code 71, 72
    miss fire in cylinder 1 and 2. What could cause this? I just replace the spark plugs and wires, coil, rotor, and cap. The car starts up fine after it has been sitting for a while, once it heats up it acts up. It idles at 500rpm and lobes a little and if it sits idling long enough it will shut down. At stop lights i have to hold the brake and accelerator to keep the car running. someone please help me before i go crazy!
    About to approach beast mode
    Boosted 4door
    well i had that problem...i had really bad idle surge and really rough idle..turned out to be my EGR valve, i removed it and put in a block off plate and now my car idles perfect. did your plugs have any oil on them?
    lawrenceville
    u sure u have the right firing order?
    110!!! NoPainT's Avatar
    LiLburn!!
    hhmmmm.... I thought you'd fix it by now. Good luck man
    WEST_SIDE
    Quote Originally Posted by 3kgtdrvr
    x2
    the firing order is correct, i am going to try the egr block plate. half of a day it was fine then shit just went down hill
    Kennesaw, GA
    wont that block plate cause you to fail emissions tho?
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    lawrenceville
    ...not if u swap it back before u go
    too many projects
    Greensboro, NC
    have you tried a differnet ecu had one do that and it ended up being a bad ecu.
    Boosted 4door
    Quote Originally Posted by JDMCD6
    depends if you are OBD1 or 2...right now running my OBD1 ecu i dont throw a code for it...im sure i will with my obd2 ecu in...
    lawrenceville
    ^u would fail either one. cel for obd2 and ur NOx would be wayyy to high on an obd1 car
