Results 1 to 3 of 3
Thread: Eboost Controler
    Privateer Racing!!
    Duluth,Ga
    Default Eboost Controler
    E-Boost controller Brand NEw!! I installed it in the car, but have never hooked it up.
    Also inluded a 75.00 custom harness connects to solenoids , and ecu and all you have to do is hit the gas.it changes gears automatically!!
    16-bit RISC FLASH CPU. No-creep gate pressure Function. 3 activation boost set points. Boost levels for each gear. Accurate boost and vacuum display: KPA, PSI, or Bar. Programmable output for water spray, shift light, etc. Over-boost alarm. Peak boost memory. e-Boost fits standard 2 5/8" gauge opening. 40 PSI / 2.75 BAR Max Pressure.
    Asking 350.00
    Privateer Racing!!
    Duluth,Ga
    LAWRENCEVILLE
    BALLER!
