Results 1 to 4 of 4
Thread: Polaris Magnum 330 4x4
    Senior Member | IA Veteran DJ XtRaKŠ's Avatar
    Apr 2001
    Roswell
    Default Polaris Magnum 330 4x4
    4 Wheeler taking a hike...lol get it. Sorry for the hunting humor.
    Brand new. Ridden twice. 11 hours, 20 miles. Camoflauge. Attatched front compartment. Perfect for Hunting Season! $5000. obo. Additional Photos available.
    Magnum 330 4x4 SPECIFICATIONS Engine Engine Type 4-stroke Displacement 329 cc Carburetion 34 mm CV Mikuni Cooling Air with fan assist oil cooler Starting Electric with recoil backup Drivetrain Final Drive Shaft Transmission P/R/N/L/H Drive System Automatic PVT EBS (Engine Braking System) Accessory Suspension Front Suspension MacPherson strut with 6.7in / 20.8cm travel Rear Suspension Progressive rate swing arm with 7.1in / 18cm travel Brakes Front/Rear Brakes Single-lever hydraulic disc w/ hydraulic rear foot brake Tires Front Tires 24 x 8-12 Rear Tires 24 x 11-12 Dimensions/Capacities Wheelbase 49.8/126.37 in/cm Turning Radius (inside tire) 71/108.3 in/cm Dry Weight 637/288.9 lbs/kg Length/Width/Height 81/46/46, 205.7/116.8/116.8 in/cm Seat Height 34/86.4 in/cm Fuel Capacity 3.25/12.3 U.S. gallons/L Front-Rack Capacity* 90/40.8 lbs/kg Rear-Rack Capacity* 180/81.6 lbs/kg Hitch Std / Drawbar Hitch Towing Capacity* 1000/453.6 lbs/kg Hitch Tongue Weight* 100/45.4 lbs/kg Ground Clearance 6.8/17.1 in/cm Instrumentation/Features Gauge Type Digital Speedometer/Odometer Standard Tachometer Standard Tripmeter Standard Hourmeter Standard High-Beam Indicator Standard Gear Indicator Standard Fuel Gauge Mechanical Warning Lights Hi Temp / Low Battery DC Outlet Accessory Colors Colors Green/Black, Sonic Blue/Black, New Break-up Camo
    Attached Thumbnails Attached Thumbnails -digicam_001-jpg   -digicam_006-jpg   -digicam_007-jpg
    IA OG
    Certified Gearhead 95stangs's Avatar
    diff a bad ass 2wheeler bump
    1995 Mustang V6
    Cardomain
    For Sale
    Myspace
    Apr 2001
    Roswell
    thank you sir....BUMP YO!
    WOW...i didnt know that the pics were that big....sry
    IA OG
    Apr 2001
    Roswell
    BUMP DAMNIT!
    IA OG
