- 95 GST For Sale
- Rep Power
- 0
95 GST For Sale $4500
95 GST
JDM swap( motor internals were super clean upon inspection)
New 2G head(replaced original head because the valves were bent)
New metal gasket(97 2.4L)
New timing belt
New timing belt tensioner
New oil pan(Original oil pan was caved in too much to keep)
New Cam Sensor
New valve cover gasket
Performance Parts Installed
Big 16G Ported(Yes a real one from FP)
Dejonn Hard upper and lower pipes
Blue aftermarket open air filter, like K&N
Apexi Dunk Style Muffler
Apexi Super AFC
Greddy Turbo timer
Blitz Blow Off Valve
255 fuel pump
Strut tower bar rear
Strut tower bar front
Aftermarket Springs dropped car over 2 inches(green in color unknown brand)
KYB struts up front
HKS 264/272 cams
ARP head studs
B&M short throw shifter
Autometer 30PSI boost gauge
Autometer A/F gauge
Dual pod pillar mount
3rd Gen 16 inch wheels
Cross Drilled Rotors Front
Parts not installed
Stereo Kenwood removable face plate and six stack CD player
Apexi electronic boost controller
3wide x 12 high x 36long intercooler with 3 inch opening
Orignal factory springs
**Dual piston calipers
**Larger set of rotors
**Brake lines
What the car needs:
New struts
Paint job
What performance upgrades the car needs:
3 inch exhaust
Install intercooler and boost controller(currently running MBC and stock Intercooler)
The car has power but needs the other items installed and tuned.
I got this car locally and it did not run because the cam sensor was bad. The previous owner had ran the car not knowing the cam sensor was gone and also did not understand how to do a timing belt. Needless to say the timing was way off so all valves got bent.
Replaced all valves, installed 264/272 cams, metal head gasket, ARP head studs, new timing belt, new timing belt tensioner. Work done by 4Gperformance.
Previous owner slammed the car with these green springs. I have a stock set of springs if you want them to bring the car up for daily driving.
Car pulls nicely but needs a tuning job on dyno to setup the fuel map on the AFC. Installing the front mount and 3inch exhaust would basically finish this car.
Power Sunroof, PW, PL, PM, PS, Leather interior, ICE Cold AC
I also have a friend at the dealer that has 2006 Eclipse 18 inch wheels to go with the car if you want to buy them for $400.00.
My new job is taking all my time and I already have two other cars so this project I chose to end and sell. Whoever gets it can take it to 4Gperformance and have them install the intercooler and make any additional piping you might need. Also 4gperfomance can make you a 3inch exhaust and keep the Apexi muffler.
First with $4500.00 takes it home. If you want to bicker about price then we can talk but I am not really in the mood to do so. I put more money into the car then planned to get it up and running.
**Items added 21 August 2006
Reason: To add Brake Upgrade Kit
This would make a nice fwd autocrosser. Bump.
- Rep Power
- 0
- Rep Power
- 0
- Rep Power
- 0
- Rep Power
- 0
Bottm end of the Engine has about 45,000 miles on it.
Intalled less then 1000 miles ago:
Rebuilt Cylinder head
2.4L metal head gasket
ARP Head Studs
Timing belt
Timing belt tensioner
Cam sensor
264/272 cams
New NGK SPark Plugs
Oil change along with new filter
- Rep Power
- 0
By the way the JDM motor is an EVO III, which is still a 7 bolt. Its a 7 bolt JDM motor not a US spec 7 bolts which had the problems with crank walk. Since I had the head off myself and Mike over at 4Gperformance can state the pistons and bottom end are not US parts due to the casting codes on the pistons.
The stock 2G intake was kept instead of using the EVO intake which had short runners.
The motor was bought and installed by BJE in Marietta prior to my purchase of the car.
- Rep Power
- 0
- Rep Power
- 0
evening bump... just before dinner
- Rep Power
- 22
y does it need panit look ok in pics.....
- Rep Power
- 0
I would paint the front of the car and thats it. Hood needs paint due to oxidization. Nose piece and fenders were replaced long before I got the car and they were red and not properly prepped. So this has allowed little spots to appear in the inner wells and around the front nose piece from rocks hitting.
But as desperate as Macco is right now you could probably get the whole car done up very well with a clear coat for under $600.00
- Rep Power
- 0
dooooo it!
- Rep Power
- 21
1953 Caddy
- Rep Power
- 0
pm me with your lowest price
- Rep Power
- 0
- Rep Power
- 0
Well still waiting for that offer
- Rep Power
- 0
Ok got a few questions about the car so I will post them here for everyone:
1) Q: What problems will I have with the car as it is right now?
A: Struts need to be replaced, most important. I hate bounce/rebound when struts are blown.
2) Q: What performance wrok still needs to be done to the car?
A: Tuning of the AFC. BUT The reason I have done this is because I still wanted to install the Front mount intercooler, and the 3 inch exhaust, along with the Apexi boost controller before tuning the car. Remember this was not a daily driver, so its not a top priority about getting tuned until everything is installed.
3)Q:What about the paint?
A: I believe you could just piant the front of the car to the doors and be done. Now as cheap as paint jobs are at Macco right now I would go over and get the Supreme paint job and ass $100.00 for the clear coat, and get the whole car repainted.
Fenders and nose piece were not properly prepped prior to being repainted and the paint has chipped off int he fender wells and grill area and you can see the old paint, which was red, the car is dark green with silver trim from the factory.
- Rep Power
- 0
Mike over at www.4gperformance.net did the engine work and will answer any questions you might have about the car, in reference to his work.
- Rep Power
- 0
- Rep Power
- 0
Slow day up here.
- Rep Power
- 0
bump sunday
- Rep Power
- 0
I was going through the garage and found the brake up grade stuff I bought last year in a box. SO I will throw it in also as item not installed.
Brake lines
All used but in great condition.
Its a great upgrade for the car since the GSTs have Single piston calipers and smaller rotors.
- Rep Power
- 0
- Rep Power
- 0
- Rep Power
- 0
- Rep Power
- 0
- Rep Power
- 0
- Rep Power
- 0
- Rep Power
- 0
- Rep Power
- 0
I would say 300HP right now. Holding it back is the fact it still has the half stock exhaust and half 2 1/2 inch exhaust. It really needs 3 inch all the way and the FMIC to turn this car into a 350HP daily driver.
- Rep Power
- 0
I have already entered into a sales contract and deposit with G.O.D. so looks like this car is off the market.
- Rep Power
- 0
Not a big eclipse fan but nice car gl with the sell
- Rep Power
- 0
G.O.D. Now has the car!!! So look out!!!
- 95 GST For Sale
- You may not post replies
- You may not edit your posts
Forum Rules
