Thread: 2.5 RS parts
    Default 2.5 RS parts
    Where can i find 2.5RS parts. I found a greddy lip, other bs. Does anyone know of a turbo exhaust made for 98 2.5rs impreza's.
    About to approach beast mode
    Are you running a turbo kit? Or are you running a swap of some sort? Depending on which you have you're going to need a different exhaust. If you have a swap then any wrx/sti exhaust will work fine.
    roflcopter V-Spec II
    Norcross
    I am going to add a turbo kit to the 2.5rs motor, or try to find a sti or wrx parts to use.
    Teh rock smoker R3RUN's Avatar
    Atlanta,GA/Tampa,FL
    Have you checked out www.rs25.com ? They probably have some sites listed there. Im pretty sure there are exhausts for turbo 2.5's as a friend of mine has one.
    It will depend on what route you go. If you're doing a swap or using wrx/sti manifolds and piping then you need a wrx/sti exhaust. If you're doing a turbokit then you will probably need a custom exhaust as most 2.5rs exhausts are only 2.5inches or smaller.
    If you're doing a kit or some sort on your stock shortblock please A)do not go above 7psi and B) check your oil as we have leaks all the time. I know several friends who have blown their engines doing both. Also going above 7psi you might be making too much torque for your stock tranny and will blow something.
    If you're looking at going above 7psi for massive power it is cheaper to do a wrx swap.
    hattiesburg MS
    you might also want to check out nasioc.com but i think rs25.com is going to be your best bet.
    v6 swap ftw!
