Results 1 to 21 of 21
Thread: Accord EX engine and tranny
    Default Accord EX engine and tranny, built for BOOST
    F22b1 (94 accord ex) SOHC VTEC
    Chikara header (on there until i went boost)
    Cometic head gasket (drops compression)
    ARP head studs
    block guard
    Competition Clutch stage 2
    fidanza flywheel
    dc short shifter.
    Whole package $1500 obo
    Will not seperate unless a reasonable offer is made for the part in question.
    Engine code is 1510638
    ALL PARTS are pretty much brand new. Perfect motor for someone that wants to boost their accord or swap it into an EG shell an have a TORQUEY motor that is TONS of fun to drive, and can handle some boost.
    cleaned it up for you , do you still have the axles an motor mounts?
    http://forums.importatlanta.com/showthread.php?t=75135
    see above thread.
    Attached Thumbnails Attached Thumbnails -dsc04536-jpg   -dsc04198-jpg
    Please post pics, Tracy. Later, QD.
    hope you dont want individuals. everything is assembled. this isn't tracy either.
    Just a pic of the engine/tranny is sufficient. Later, QD.
    So this is/was BOoOSTED, but now u have taken the turbo kit off.....Does it smoke? how are the bearings? how many miles while boosted? how many psi were you running? why did u take the kit off? have u doen a compression test without the turbo kit now?
    it was never boosted, it was built for boost, he decided to move onto a different project
    THROW TRACY IN AND ILL PICK EVERYTHING UP TODAY.
    Jan 2003
    kennesaw ga
    1500$ is ALOT for what you got. those swaps are a dime a dozen.
    It does say OBO. And 1500 for a turn key full engine and tranny with mods? Who has done that swap?
    Senior Member BlkCD5's Avatar
    What is the weight of the fidanza flywheel? How much will you take for the clutch/flywheel combo or each seperately?
    I am not sure what the exact weight of the flywheel is. I know its pretty damn light compared to stock. If I had to guess I would say somewhere around 8 lbs. For both I would take $500. Seperatley $300 for the flywheel and $250 for the clutch.
    Val for president!
    Facebook.com/TracyATL
    Bump Tracy . Also how much for the chikara header and is it ceramic or black? Sorry, forgot to ask about it earlier.
    how much do you want for just the tranny?
    About to approach beast mode
    It's not ours really. It's Brandon's. When he has time at the end of the day he'll check this and answer everything.
    Val for president!
    h series
    norcross
    are u willin to sell the short shifter ill give u my old one plus cash if ud like or just cash straight up i dont want it to effect ur sell or anything just let me know in Pm thanks
    well a lot of questions here. thanks first off. The short shifter is $30. It is not a whole assembly like most others. it is an insert that shortens the throw. The Tranny is $350. The chikara header is black and is ceramic coated. However it is starting to flake a little. I will put up a pic of it. thanks again
    u[p
    Kennesaw, GA
    Hey can i get the Idle air control valve and the EGR valve? I got $100
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
