Results 1 to 16 of 16
Thread: FS: P2T ECU, MSD 6A, ACL Crank Bearings
    Certified Gearhead Blaze the chemi's Avatar
    Default FS: P2T ECU, MSD 6A, ACL Crank Bearings
    MSD 6A $75
    P2T OBD2B 99-00 Civic Si ECU $50 (SOLD)
    ACL Crank and Thrust Bearings fits:B16A, B18A, B20A, B21A1, D16A, ZC $70
    MSD is fine. I just don't need it. Stock ignition is great.
    The ECU works. I was just comparing my stock ECU making sure it is working fine.
    I rebuilt my engine last fall and only needed the rod bearings. Never opened these.
    Straight O.G. BlackEj6's Avatar
    StockBridge
    you willing to trade the ECU and/or MSD for anything listed in this thread?..
    http://forums.importatlanta.com/showthread.php?t=74440
    c-ya sirhatch1030's Avatar
    southside
    r u saying u have bearings for all thise motors or u saying they fit these motors because the bearings r not the same. for the motors listed they r all diff sizes.
    Quote Originally Posted by BlackEj6
    Nope. I'm getting rid of stuff.
    Quote Originally Posted by sirhatch1030
    I'm saying that the bearings will fit in these motors.
    southside
    they will not fit in all these motors the cranks r not the same size.
    These are the engine codes printed on the sticker from ACL. Call them to correct their typ-o.
    the main bearings are all the same for ANY b series motor. Rod bearings are the only ones that are different. LS/B16/B20 bearings are wider, GSR are narrower
    Main bearings are all the same. same goes for thrust washers.
    ACL bearings are all HONDA GREEN SPEC so check your clearances
    southside
    he said htey would fit zc and d16 , thats what i was refering to .
    oh ill agree with that, i have a set of Mains here an it lists all B series, not D series
    Correction...
    The Thrust Washers will fit B series and D16A, ZC.
    The Main Bearing will not fir the D or ZC. Only the B.
    Thanks Sir Hatch and VtecKidd for pointing that out
    The ECU has been sold.
    StockBridge
    Thanks man..The ecu solved my problem
    Great. I figured it would.
    ttt
    TTT again.
    I know some poeple need this stuff right?
    Banned lsxtreme's Avatar
    how much for the bearings
    $70, but someone else is inquiring about the bearings, but they have been stalling for 2 weeks. You want them?
