Results 1 to 3 of 3
Thread: talon not wanting to idle right
    buford ga
    Default talon not wanting to idle right
    i have a 90 model talon tat wants to idle real low then surge high now it was on a computer and the code was for a tps.i wanted to no is there something else it could be are should i just go buy a tps and trust the comp.cause the thing is iv seen other forums say tat is has alot of other stuff tat goes wrone tat makes it do tat as well.any take on this.or should i just trust the comp.
    your moms house
    you should trust the comp and hit f7
    FUCK B&D COMMUNICATIONS!
    Boosted 4door
    A bad TPS is definately the culprit of surging idle....
    please go back to second grade and learn how to spell lemme correct it for you
    i have a 90' model talon that wants to idle really low then surge high. (removed "now") It was on a computer and the code was for a tps. I wanted to know if there is something else it could be,or should I just go buy a tps and trust the computer? because the thing is i have seen other forums say that it has a lotof other stuff that goes wrong that makes it do that as well. Any takers on this? or should i just trust the computer?
