Results 1 to 11 of 11
Thread: Engine break in article
    Senior Member 99SI's Avatar
    Jackson
    Default Engine break in article
    COPIED FROM THE LASKEY RACING SITE. FOUND FROM A LINK ON H-T.
    The Proper Method to Break in your New Engine
    One of the most asked questions is how do I break in my new motor? The short answer is that no break-in is necessary. The only thing that is necessary is to seat the rings. All clearances and fitments should be perfect after blueprinting and precision assembly. So how many miles do you have to drive it to seat the rings? The cylinders are round, the rings are round, the bore is freshly honed and therefore your engine should be ready for tuning immediately. They will continue to seat better over a short period of time but you should be ready to go tune right away.
    Do I need to drive it 500 miles before I tune it? Absolutely not. How about 50 miles? No. Perhaps the best thing to do is to drive it all the way to your trailer and tow it to a competent tuner. In second position on the “things NOT to do list” is trying to break in an un-tuned engine by driving it. Too lean an air/fuel will begin to heat and distort parts, too rich will wash the oil off the cylinders causing premature wear. What is in first place on the “things NOT to do list”? Boost on an un-tuned motor. Within 2 to 3 seconds the pistons and cylinders can be ruined.
    Well I did put in a new base map or I’m just running off the stock Honda computer. Can’t I drive it like that for a few miles? I’m not even boosting. Well what is the base map? Just someone’s idea of what numbers will start your car. Just an educated guess by someone who does not have a clue what components you are running in your set-up. It’s not intended to drive on for any extended period of time. The same with that stock Honda computer. It could be ok but it could also be dangerously wrong.
    So what exactly do I do at the first engine start-up? Pull the spark plugs and crank the motor with your starter for a maximum of 30 seconds or until you see the oil pressure gauge begin to register. Re-install the plugs and wires and fire up that candle. While keeping one eye on the oil pressure gauge, use your other eye to scan for fuel leaks. If there are no fuel leaks, look under the motor for any major oil or coolant leaks. If that is ok, run the engine for 5 to 10 minutes while keeping an eye on the temperature and pressure gauges. Keep the rpm’s between 1000-3000. Shut the engine down and double-check everything. You are now ready for tuning.
    But my engine was already tuned from my previous set-up. Well, what happened to your previous set-up? Did you melt a stock piston or crack a cylinder? No problem because now you have forged pistons and sleeves? Wrong. Although you now have stronger components that will take more abuse, you are still not right on your air fuel mixture. Get that thing tuned properly ASAP.
    OK, I did it my way instead of yours and now I’m burning a lot of oil. What happened? Well basically you scarred up the skirt of the piston, messed up the surface of the cylinder wall and maybe even egg shaped the cylinder. New pistons are tapered smaller on the top to larger at the bottom of the skirt. Your piston to wall clearance is measured at the bottom of the skirt. As the engine warms up to operating temperature, the upper portion of the piston begins to expand slightly. The bottom of the skirt does not expand much. When you boost in a lean condition, the upper part of the piston expands quickly. Since the ring land area is cut smaller than the tapered skirt below it, the first part of the piston that pushes into the cylinder wall is just below the oil ring. Thus you will see the worst scarring on your piston right under the ring lands where the excess heat is the highest.
    The more heat that is generated, the harder the piston pushes into the cylinder wall. The uninformed would blame the piston damage on bad piston to wall clearance. Untrue. If that were the problem, the damage would show up at the very bottom of the skirt. What has happened is that you have expanded your piston to the point that it has just ground itself into the cylinder wall. Keep expanding the piston by super heating it and it will push your cylinder egg shaped and maybe even balloon out the cylinder slightly. At the same time this is happening, your ring lands will begin to distort to where they will never seal properly again. Sometimes after doing this, the engine will still run but it will be a smoker. This all happens in a few seconds of high boost with a lean air fuel ratio. Also it can happen from 500 freeway miles of driving where the tune up is off enough to build excess heat at a slower rate, thus doing the same damage over a longer period of time…but the end results are the same. Death to your pistons and cylinder walls.
    OK, I’m just going to turn the fuel pressure way up and run extra fat, that way I won’t hurt anything. If you run too rich, you will “wash out” the rings. First, excess fuel will run down the cylinders taking the lubricating oil with it. This promotes direct metal-to-metal contact between the rings and the cylinder wall. This contact does several things. The upper ring begins to wear quickly. The middle ring is actually designed as a tapered oil scraper (it is not used for compression control at all) and the taper will begin to wear down to where it becomes flat rather than angled. When that happens, it can no longer control oil away from the combustion chamber. The last thing that happens is that pretty cross hatch design begins to wear off of the cylinder wall. While most people think that the cross hatch is there to help seat the rings, it also has a secondary purpose. That is to hold microscopic amounts of oil in the grooves to help lubricate ring to cylinder walls. With the walls smooth and no oil control help from the middle ring and a tired upper ring, oil will begin to mix with fuel in the combustion chamber. When this happens, your 93 octane fuel probably hits a value of about 80. Then detonation comes into play and begins to beat holes in the pistons, among other things.
    So whom can I blame for this mess? The blind machinist that honed my piston to wall clearance? That poor quality Brand X piston manufacturer? The idiot pro engine builder that assembled my block? My ex-friend that helped me put this all together? Those ignorant engineers that gave me a bad base map with my engine management system? The guy on the internet message board whose buddy knows that it takes at least 1000 miles of break in before you can tune an engine properly? All of the above? Probably none of the above. Go look in a mirror and ask…who started this engine and had no idea what the air fuel ratio was? Who just wanted to jump on it one time to see if it would haul? Who didn’t know that their injectors were at 100% duty cycle at 4000 rpm but they wanted to see how it would run at 6000 rpm? Why it was you. Get that thing tuned right away. You will notice that the more you drive a tuned motor, the stronger it will feel. This is just the rings seating in their final 5-10% as they thank you for tuning first.
    Slow... mp5o's Avatar
    Another good article on breaking in motors... http://www.mototuneusa.com/break_in_secrets.htm
    and people still question our methods of break in lol.
    we put them on the dyno an let them rip to redline, thats the only way to do it IMO
    known as Charles
    We have had motors that start for the first time on one lift, heat to operating temp, change oil, move to dyno, tune, make 500whp with about 10 miles on them. Like the first paragraph says, if the motor is built right then you have nothing to worry about. I know a guy that has a 10sec VW bug that has started new motors for the first time in the burnout box and then ran 10sec passes.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    Jackson
    I just hope that it won't have a negative effect for me driving my newly built motor from Milledgeville to Powder Springs to get tuned. I may look into trailering it up there to avoid any issues before it gets properly tuned.
    The main thing is repeatedly change the oil the first 500-1,000 miles....and still not exactly sure on the disadvantages of using synthetic oil during "break-in". I think i changed mine at 50, 500, and 1,000 then switched to synthetic at 2,500...can't remember
    Jan 2005
    Columbus, Ga
    i've only redlined my car once since i got it, should i try to more?
    i know you love my swagger
    OG Black Delegation member
    RIP My Homie Elliot Sloan
    Formerly Spyder Man
    Buford, Ga
    Quote Originally Posted by B16a2 Civic
    go start your car.. let it warm to proper temperature.. throw a brick on the gas pedal.. go back into work.... it will help clean out the motor.
    :boobies:
    Jackson
    ^^^LOL. PUSSY!!! It's just that an engine tends to get into a comfort zone depending on how it has been run. I see it all the time in the used car business. You get that one owner car that a little old lady drove and it wants to run 45-55 mph all the time, it really feels like you are going to tear something up if you try to run 65-75. At the same token you can get in an identical car that someone else who drove fast and hard and that car will want to run at a higher speed and feel smoother while doing it. At this point with your car if you drive it hard more it is not really going to do anything. Drive your car as you normally would. My old motor wanted to run 75-80! lol. That's where it felt comfortable and you could tell it didn't mind revving up high b/c it was done since it was a virgin and i popped it's cherry at 9500 rpm!
    Jan 2005
    Columbus, Ga
    Quote Originally Posted by Spyder
    nICK, I SENSE SARCASIM
    The first 5 minutes is the most critical...once the valves seat and everything it should be all ready to go...if it's going to break or fly apart it will most likely do it then up to the first 50 miles or so
