Thread: How to adjust timing on a 1992 honda accord
    Suck my country R@@T SOHC MONSTER's Avatar
    Dallas, GA
    Default How to adjust timing on a 1992 honda accord
    I am trying to figure out how to adjust the timing for a 92 accord. I need to know which pulleys to turn and what are the points they need to be at. They seen to have no distinguishing marks for TDC. Thank in advance for the help.
    -Brandon
    the cam gear should be marked, have two notches to line up horizontally, and the dot for up... the crank should have a little notch in the back of the pully
    Senior Member BlkCD5's Avatar
    I got a Chilton's manual and can scan the diagrams if you want. LMK
    Dallas, GA
    Thanks guys, I am going to pick up a manual today and see where it leads me. I had a fuel problem but turned out to be an O-ring problem so it was an easy fix. I will keep you informed if I have any other questions. Thanks!
    lawrenceville
    are u trying to adjust the timing or change the timing belt and set the new one up right?
    Dallas, GA
    Quote Originally Posted by 3kgtdrvr
    Timing belt is on. The cam gear is set to TDC but apparently there are 2 other pulleys that need to be adjusted as well... That is what I am trying t figure out.
