Ok so the 240sx is put together and cranks up no problem. WOOT.
The clutch pedal doesnt have pressure tho. Its just kinda loose. I got a new slave cylinder since the old bleeder on the old slave cylinder is broken. I tried bleeding the system (dont know if i did it right) but it prolly did. I also tried adjusting the pedal (dont know if i did this right either) but still no luck. The pedal is just chillin there. When the car is turned on, i push in the clutch and try to put it in reverse but it doesnt wanna go in. Actually non of the gears will go in. The i turn the car off and put it in reverse. I then crank it up, and before i even let the clutch go, the car just jerks back when i try to crank it up. I have no idea what to do but i need to get it running. Could it by any change be the throw out barring?
I don want to give up on this even tho the insurance is giving me issues with this car.
