Results 1 to 3 of 3
Thread: swap question
    Dtran
    Default swap question
    i got a obdI gsr that is wired up for an eg. well i pulled it out and going to put it into a 96 dx coupe. my question is, which wiring harness do you use? can you use the stock one? i am using the conversion harness for obdII to OBDI so how do i run the vtec? or do i have to buy the 99-01 si wiring harness?
    WEST_SIDE
    u can use your dx hareness and all the needeed wires to run a DOCH vtec motor.
    you already have the obd2-obd1 conv hareness. so you good to go
    Dtran
    thanks
