Results 1 to 5 of 5
Thread: IACV b18a1
    Default IACV b18a1
    i bought one awhile back from a guy on this site, and it works,.... kinda but my car does this weird idling thing and doesn't quite run right untill the check engine light comes on, it also has been motor boating on occasion.. so i need an idle air control valve that was made for the b18a1... i've got one on now that went to a b16 i think. it doesn't quite line up right.
    and prefferable the tubes that go with it as well.
    COG
    if you cant find one, try Honda parts connection on peachtree ind. I bought one for my d16y8 for 40$, when i installed it it made my car do crazy stuff, like make it raise up to 2500rpms while i was not in gear, so i unpluged the negative battery terminal, and turned my Air controller screw all the way down, i idle at like 700 now and have not had problems since. Hope you get it fixed. If you want i can get the IAC for you and you can pay me what i bought it for plus gas or something, lmk, HPC is like 2 min from my house. Holla
    you got their number???
    and what screw are u talkin about? i may need to try what u did.
    anyone?
    __DailyGrind
    it might not be the IAVC....so double check again
