Results 1 to 10 of 10
Thread: Vibration Problem
    West Staines
    Default Vibration Problem
    Okay... when im accelerating the whole vehicle vibrates.. what could this be? my tires are fine, but... ive noticed that i may need another "new" driverside mount or bushing and im missing a bolt at the rear mount. Could this be the only thing left that could be causing this horrible shake?
    i just wanna know what else i should for and what other changes may have to be made...
    thanks in advance for the help guys.
    your moms house
    that would probably do it.
    FUCK B&D COMMUNICATIONS!
    Hampton, Ga
    alignment?
    h series
    norcross
    ya bro check it mounts if it isnt ur tires
    Misfire? Bad c/v axle? even in my cars with solid motor mounts it doesnt particularly vibrate during acceleration.. and tires vibrate all the time at moderate to high speeds usually. plus they are typically worse at multiples of themselves.. IE bad vibration at 35mph.. will be bad again at 70mph. Ive had a c/v axle joint lock up and caused the car to vibrate something fierce while accelerating
    Getting there admedlin's Avatar
    Columbus
    Mine vibrates pretty bad too. I checked the mounts and they all seem fine. A mechanic told me that sometimes if the exhaust is loose and moves around a little bit, it could feel like your whole car is shaking. I found out that the header on my car isn't bolted to the bottom of the car, so basically its just hanging there. When you hit the gas, more air flows through causing it to move around. So maybe check your exhaust hangers. Also check the axles
    Columbus
    Well i just got back from the exhaust shop, the hanger was causing the shaking problem. So get under your car and check out your exhaust hangers. If thats it, its an easy, cheap fix
    Certified Gearhead aubry588's Avatar
    i had the exact same problem and i changed my bad rear mount and it fixed it..
    IAs Resident Pot head
    for a second there, I thought this post said "Vibrator problem"
    West Staines
    Thanks for all the input guys! im gonna check out all of the things listed this weekend. But if anybody else comes up with any other possibilities, please feel free to post
