Thread: FS: MSD Fuel Pump Boost Control #2350
    Griffin
    Default FS: MSD Fuel Pump Boost Control #2350
    its new....cost $235
    selling for $175 obo.
    email [email protected]
    located in griffin , georgia.
    Griffin
    MSD FUEL PUMP BOOSTER ( 2350 )
    Adding a turbo or supercharger to your engine is a great way to improve the power of your car. But you have to remember that when more air is being pushing into the engine, the need for additional fuel raises proportionally. Meeting these new fuel demands could mean larger injectors or ECU programming, both which can be pricey. This new fuel Pump Booster is the economical (and easy) answer for your engine's new fuel demands. The Booster will supply the electric fuel pump which increased voltage in relation to the manifold boost pressure. As boost pressure increases in the manifold, the MSD Booster will increase the voltage to the electric fuel pump. The amount of voltage is adjustable with a potentiometer from a range of an additional 1.5 volts to a maximum output of 22 volts over a range of 5-30 psi.
    Griffin
    electric fmu
    Griffin
    make reasonable offer
    Griffin
    up
    Griffin
    ttt
    Griffin
    up
