Results 1 to 24 of 24
Thread: FS: Honda D-series Engine parts and other misc Civic parts
    Cool FS: Honda D-series Engine parts and other misc Civic parts
    I recently built a D16Y8 for my 98 hatch and I have a ton of parts left over from both my stock motor and donor motors. Here's a list:
    1998 D16Y7 from my 1998 hatch. Full motor EXCEPT the crank and rods. I had to rob those due to machine shop screw-ups on some of my parts. The engine has 122,750 miles, and everything still looks great. Slight carbon build-up on pistons and at the top of the cylinders. Factory crosshatch is still apparent on cylinder walls. Includes the engine wiring harness and P2E computer. I also have the stock intake and exhaust manifolds, if anyone's interested. - $SOLD!
    1998 DX S40 transmission - 122,750 miles. It is the main reason I replaced my stock motor. This thing may make a better boat anchor than transmission. Before being replaced, it had a 2nd gear pop-out, ground 3rd and 5th. Certainly needs a rebuild before being used for long periods of time. Not really looking to get anything for this tranny - come get it and its yours. - $GONE!
    Miscellaneous D-Series Stuff:
    D16Y7 exhaust manifold with cat converter - $40
    D crank pulley - $5
    D water crossover tube (goes behind motor between water pump and thermostat housing) - $Free if you want it
    D16Y7 B-pipe - $5
    D lower timing belt cover - $5
    D dipstick - $0.50
    D alternator and alternator mount - $20, great working condition
    D oil pump (60k miles) - $15
    2 D water pumps (60k miles each) - $5 each
    D starter - $20
    D driver's side upper engine mount - $5
    D flywheel (122k miles, good condition, but could use resurfacing) - $10
    4 P2E pistons from my stock motor - slight carbon buildup, but can be easily removed - $15
    D clutch cover - $1
    6 D-series connecting rods - $5 for the lot
    D oil breather chamber - $1
    P2P engine block stiffeners - $1
    D slave cylinder - $5
    D shift linkage - $5
    D16Y7 Intake manifold/throttle body/fuel rail/injectors - $20
    D16Y7 plastic intake box/piping - $5
    D16Y8 EX oil pan (unmolested) - $20
    D16Y8 crank - had a problem with con rod movement after this visited the machine shop. The crank would need to be mic'd to make sure it will work without problems. Otherwise, it could make good furniture - $1
    Misc. Civic Parts:
    I upgraded to Integra brakes front/rear and want to see if anyone has a use for my old parts. I have the front calipers/brackets/lines, rear trailing arms with drum brakes/ebrake cables/lines and the stock prop valve - $40
    This a pretty inclusive list, though I may not have listed everything I have. I'm located in Athens, GA, and just looking to clean out my storage unit. Hit me up if you're interested in anything. I can ship most of the small stuff if you pay for it; the big stuff would be pickup preferred.
    Brandon
    brandonw "at" mindspring "dot" com
    Per mods, post updated with prices. I feel they're more than reasonable, so please don't take cheap shots with nutty, lowball offers. Thanks.
    Brandon
    ATH GA. SRCRX's Avatar
    On the drum set!!
    Thumbs up
    BUMP
    Senior Member kaotickaozpunk's Avatar
    hey im interested in your block...where you located..
    Quote Originally Posted by vtec_hawj
    Got your PM, replied.
    Brandon
    PS - i'm off to Limerock Raceway on Wednesday to race and will probably not be able to respond to emails/posts/PM's. I'll be back on Sunday and will return all messages at that time. Thanks for the interest.
    I'm back from Limerock. Everything still available.
    Brandon
    Skyline Powered!
    woodstock, GA
    ill give u 50 bucks for the motor. i blew mine so i need one. where u located. ill pay cash.
    Still Here LQQKITZME's Avatar
    Roswell
    I need a 4 wire O2 sensor have one?? in working cond of corse
    Quote Originally Posted by LQQKITZME
    Sorry, but I re-used the ones from my old motor in my new motor since they were working fine.
    Brandon
    Bump. Everything still for sale.
    Brandon
    Columbia, SC
    That's a nice collection that you got there
    I got a bunch of D shit that I'm trying to get rid of. TOO MANY PROJECTS AT ONCE
    Thanks for the bump. Yeah, I could almost build another one.
    Brandon
    Turbo City USA
    PM'd
    Bump... Everything still available.
    Brandon
    itakepictures
    changaroopouch
    pics of the oil pan? :P where are you located?
    Titties!!!
    where are you located, sent you a pm
    stock EK
    home
    i buy the engine wire harness..can you meet me somewhere like winder..
    Titties!!!
    i will take head and block etc. tonight or tommorow, check your pm.
    San Antonio, TX
    you changed the brakes over?
    do you have the ENTIRE RR hub assembly?
    twoONEoh
    Quote Originally Posted by ekcivic9
    Damn, wish I had seen this earlier... I'll get pics for you. I'm located in Athens.
    Block/head now sold, along with harness, ECU and intake manifold. Thanks, preferredduck!
    Brandon
    Quote Originally Posted by Cremepuff
    Yes, I do. I have everything except for the drum, which was pretty worn, so I threw it out.
    Brandon
    Titties!!!
    your welcome!!
    Senior Member SE-Rious©'s Avatar
    Have anything left over from the d-series ? if so im interested.thanks
    Titties!!!
    everything seller has is in great shape, he knows what he has!!
