Results 1 to 10 of 10
Thread: Overheating
    TopSecret
    Cobb County
    Default Overheating
    Here's the problem my sr20det has been overheating the past few weeks, it only begins to get hot when I'm on the highway for a long period of time but driving stop and go it stays normal the only thing that I've changed is the spark plugs, someone told me I might be using to hot of a plug I'm not sure need some help ASAP
    Coming Back...................................
    Supraforums.com
    lawrenceville
    i say start off with flushing the coolant and putting a new thermostat in and if it doesnt work then it wont hurt to have that done anyway
    prelude ur ass
    duluth
    eww if its been overheating for over a week by now the head gaskets are probably blown too because i got my prelude overheated and after like a couple of weeks the car would have trouble starting in the cold. and when i took it to honda they said the car overheated and blew the gasket right away.
    lawrenceville
    it depends on how hot and how long and all sorts of stuff. i just fixed a car this week that overheated and she didnt crack a head or block or even blow the head gasket. its possible it did but its also very possible it didnt. if u kept an eye on the temp gauge and made sure it didnt get really hot but just that it was getting hotter than normal then id say go for the coolant and thermostat first.
    PS: dont drive a car that overheats lol
    TopSecret
    Cobb County
    It only overheats if I drivie for about 15 min on the highway and hell yeah I kept my eye on the gauge
    Supraforums.com
    WEST_SIDE
    Quote Originally Posted by Prophet180
    so does it over heat or run hotter then normal temperature?
    Its a Nissan, what do you expect? BTW, I do remember you calling me out a couple months ago saying I was slow or something like that. How about a friendly run after you get your problems situated.
    Are you still running a SMIC ? Also If your A/F Is High it can cause it to run Hot...Do you know your A/F ?... Plus a Water pump will do it too...There are a Number of things it could be.. Post what you have done.."MODS"... Maybe we can help with a little more info...
    TopSecret
    Cobb County
    Are you sure I called you out or my boy with the black 240sx which he doesn't have anymore but I'll still run you when everything said and done
    Quote Originally Posted by KevinT707
    Supraforums.com
    TopSecret
    Cobb County
    Quote Originally Posted by 1civic
    Front mount, I have no A/F meter so I'm not sure and I have no "MODS"
    Supraforums.com
