Results 1 to 36 of 36
Thread: 240SX Oil Leak
    No autobahn needed.
    Stone Mountain
    Exclamation 240SX Oil Leak
    I have a 1990 Nissan 240SX SE / SOHC / 5 SPD
    I have a major oil leak
    The oil seems to be leaking around where the pullies are
    I thought it was the oil pan, but the oil is coming from above that
    It only leaks while its running and 5 mins after it runs, and it leaks quite a bit
    I thought it was the head gasket or valve cover gasket but while the engine is on, no oil leaks from there, from what I can see
    I MIGHT be able to get pics of the area of where it leaks, but im not sure if my phone will take a well enough pic for you to see
    Help is greatly appreciated
    Thanks guys
    Push more than others think is Safe
    Expect
    more than others think is Possible
    Drifter/Kneedragger
    Buford, GA, USA
    that's not very descriptive . WHAT pullies does it seem to leak near? the only pulley that could really leak engine oil would be the crank pulley, which would be a front main seal replacement. pretty cheap and easy to do.
    if it's the timing chain cover gasket then get ready for lots of cursing.
    No autobahn needed.
    Stone Mountain
    I think its the front main seal replacement
    how exactly do I do this?
    and sorry for not being to descriptive, didnt really know to to explain it to well
    Expect
    Drifter/Kneedragger
    Buford, GA, USA
    Quote Originally Posted by NcTurnL
    front main seal is pretty simple. remove the bolt that holds the crank pulley on and remove the pulley (might need a pulling tool for it if you don't have one around). after the pulley is off you remove the seal using a seal puller (some like screwdrivers, but the seal puller works great and is a cheap tool to pick up). after pulling the old seal out spread some grease or oil on the new one and tap it in gently using a soft object like a plastic hammer or block of wood with a nice flat end on it. tap gently around the outside edge until the seal face is flush with the cover all the way around and then fit the pulley and tighten it.
    if you find space is tight to work in then you can pull out the radiator to give extra room .
    No autobahn needed.
    Stone Mountain
    Thank you so much
    hopefully this solves my leaking problem
    Expect
    WEST_SIDE
    Quote Originally Posted by HiPSI
    im not to sure of the nissan but ya hes right most likely front seal and or chain cover. should be relatively easy to find once u get int here
    No autobahn needed.
    Stone Mountain
    Thanks man
    If it isnt the front seal, how do you check if its the timing chain cover gasket?
    Expect
    WEST_SIDE
    Thanks man
    i think i have a service manual let me look for it i had a nissan WAY back int he day . wether i find it or not i'll post uplater
    No autobahn needed.
    Stone Mountain
    Greatly apprecaited
    Thanks man
    Expect
    WEST_SIDE
    sory bro i cant find it i dont hink i have it with me any more . but if i find one on the net ill give you the link
    No autobahn needed.
    Stone Mountain
    Aight
    Thanks either way man
    Expect
    No autobahn needed.
    Stone Mountain
    Alright, I took a look at my car this morning and tried to see where exactly the leaks are comming from
    Well,right under the pully that controls the fan, theres abother pully, one oil leak is comming from around that area
    The other leak, is comming from either the head gasket or the valve cover gasket, I notced when I was looking at the side of the valve cover that there was oil slowly comming out and that oil was hitting the headers which caused some smoke :-(
    Can you guys help me out with this?
    where could the first leak be, and also, would it be the valve cover or head gaskets?
    Thanks guys
    any help will be greatly appreciated
    ...I really need to get this car running
    Expect
    No autobahn needed.
    Stone Mountain
    To change the front main seal, I know I have to take out the pully, Do I also losen the belts that it connects to to take the pully all the way off?
    Expect
    Drifter/Kneedragger
    Buford, GA, USA
    yes you will need to remove all of the belts from the car to get the crank pulley off. then remove the pulley completely and you'll see the black round seal in the cover around the crank.
    the oil falling on the exhaust manifold is likely from the valve cover gasket, another easy swap. the headgasket leaking oil in that area is mildly unlikely. the easy way to find the origin of a leak is to clean the hell out of everything, get all the oil off you possibly can, then run the motor and just watch for leakage. if the car is just sitting and running then the oil will run down the motor from wherever it's coming from so it's easier to trace than if you've been driving the car around and airflow in the engine bay has pushed crap around.
    No autobahn needed.
    Stone Mountain
    Alright
    Thanks man
    If I take all the belts off, is it going to effect the timing on my engine, or will everything be fine?
    Expect
    WEST_SIDE
    Alright
    Thanks man
    Timing shouldnt be effected . your jsut removing the accesory belts.alternator, PS, maybe AC compressor belt . ect ect.
    No autobahn needed.
    Stone Mountain
    alright cool cool
    Thanks man
    now what do I do about that damn tight as hell bold on the pully?
    Expect
    WEST_SIDE
    alright cool cool
    Thanks man
    use a impact. =D. or if nissan has a specialty tool liek honda get ahold of it .to hold the puley will u brake it loose
    No autobahn needed.
    Stone Mountain
    Quote Originally Posted by smoke_Em
    I need to get ahold of an impact
    Now I got a perfect reason to get a air compressor and an impact
    hahahaha, im not sure if im ready to brake it just yet
    Thanks alot for the info though
    Expect
    No autobahn needed.
    Stone Mountain
    alright guys
    I got the front seal replaced and that leak is fixed
    Now I found another leak, next to the leak from the cover gasket
    I have no idea where exactly this leak is comming from, I know that its leaking somewhere to the left of the crank pully if you where looking at the car from the front
    It isnt a major leak, but tis annoying as hell, I was guessing the oil filter?
    Can ya'll head me in a certain direction here?
    Thanks alot guys
    Expect
    No autobahn needed.
    Stone Mountain
    This is a quick random question about my valve cover
    I didnt want to start another thread
    are ALL the bolts used to attack the valve cover to the head the exact same?
    for some reason, after I put the new cover gasket in, and tried to put the cover back on, one side ALMOST all the bolts tighten, the other NONE of the bolts tighten
    can you guys help me out with this one?
    SORRY TO ASK SO MANY QUESTIONS
    but ya'll are truly VERY helpful
    THANK YOU
    Expect
    WEST_SIDE
    THANK YOU
    i ready dont know since i never touched a nissan . but take them off and put them side by side it will tell you which are longer then the rest and go from there
    No autobahn needed.
    Stone Mountain
    I think the owner before me stripped the area where the cover bolt goes into the head, I think that why the bolts go in, but dont screw in.
    I really dont want to helicoil this beacuse I dont know how, but I dont think i'll have a choice
    Dammit, can someone help me out?
    Expect
    IAs Resident Pot head
    sounds like a front main seal...
    No autobahn needed.
    Stone Mountain
    that was one of the leaks but I already replaced that
    This othr leak is coming from teh left of that
    Expect
    20 side of thangs
    it's a 240. its made to leak stuff.
    No autobahn needed.
    Stone Mountain
    naw
    Expect
    110!!!! Nopaintsls's Avatar
    some where near YOU!!!
    Quote Originally Posted by PSINXS
    yup... nissans SucK balls....
    No autobahn needed.
    Stone Mountain
    I dont think so, but its all on the persons own personal opinion
    I still need help with this leak though
    Expect
    from left of that? hmmmm My guess, the timing chain cover. take it off, check the gaket, replace if needed, it might even be cracked, cause My last 240 was like that. people often crack them when doing a timing chain job cause there are a couple of bolts that are hard to find and most people end up cracking the cover around them.
    No autobahn needed.
    Stone Mountain
    Alright I'll check that and see how it goes
    Thanks man
    Expect
    let me know what you find, oh buy a can of brake parts cleaner and spray the fuck out the area, clean it very well, and then run the engine, the leak should be immediatelly visible that way.
    No autobahn needed.
    Stone Mountain
    I havent checked the timeing cover gasket yet, trying to figure out where it is
    but, I was wondering if it could be the oil pump?
    Expect
    possible as that is where the oil pump is located, but if its above the crank pully, then ummmm
    No autobahn needed.
    Stone Mountain
    Hmmm
    Im just going to part out my engine
    save me some moeny for my new one :-)
    Expect
    ok
