Thread: ecu chipped or not
    who knows.
    Default ecu chipped or not
    is this ecu chipped or not and what is the vtec engagment point on a pwo ecu ......
    Attached Thumbnails Attached Thumbnails -ecu-inside-jpg   -ecu-inside-2-jpg   -ecu-inside-3-jpg
    WEST_SIDE
    this is from an articlei have saved on my pc
    OBD0 ECU Chipping
    If you have a OBD0 ECU, chipping the ECU might not be straightforward. Almost ALL 90-91 PM6, PM7, PR4 and PP5(with catalytic converter) ECUs had external EPROMs, and are easy to change the program on. Almost all 88-89 PG7, PM6, PM7 and 88-91 PM8 ECUs did not have an external EPROM. It is possible to chip these ECUs, but it requires considerably more work and is beyond the scope of this article. See Chipping An88-89 ECU for more details. The following ECU is a PM7 that does not have an external ROM:
    If you are luckier and have an ECU with an external EPROM from the factory, the ECU you have will look more like this:
    An OBD0 ECU with an external EPROM is very simple to chip. First, cut all 28 pins with a razor blade or utility knife. BE CAREFUL YOU DO NOT SLIP AS YOU CAN PERMANENTLY DAMAGE THE CIRCUIT BOARD. It is not absolutely necessary to do this before desoldering, but removing the chip will make it much easier, particularly if you do not have a good desoldering station. Once the original ROM is desoldered and removed and you can see through the holes in the circuit board, add a socket for an EPROM and then place the new ROM you have created into the socket.
    http://www.pgmfi.org/twiki/bin/view/...0_ECU_Chipping
    scotty says NO
    it looks like the 28 pin chip is the factory chip soldered to the board...not chipped. pwo is a jdm vtec ecu. it can be socketed/chipped if you'd like. let me know if i can be of assistance.
    who knows.
    okay all this is fine - the ecu is more than likely bad - very hard to explain but the car will start acting like it is out of gas like puttering when u hit the gas , but will not die , but u turn the key off and crank the car back up and it drives fine ..... very weird but it may be something else if u guys know something i dont but scotty pm me a price on me supply a p28 on chipped or socketed , and u tune right ?
    pm sent.
    btw is that ecu throwing any codes when it does that?
    who knows.
    no codes at all doesnt have a o2 sensor connected at all and its not throwing a code ....... weird . im gonna call u today scott
