Results 1 to 31 of 31
Thread: quick question....
    the county
    Default quick question....
    got a 1995 civic ex that skips when you give it so much gas(push the pedal down).
    it still redlines though.
    i have been told that it had jumped time a tooth. but i think its a the fuel pump.
    i have also been told it might be the distibutor.
    any thoughts of what it could be?
    and i know this is the wrong forum but no one ever responds to this in the general tech forum.
    Custom User Title: Seymour222's Avatar
    The list is almost endless with possibilites.
    ***POKE*** Scrappy's Avatar
    yup that was my problem... and took many different things till it stopped... sucks though just dont get on it so much... its a civic it doesnt like it hard
    Quote Originally Posted by Scrappy
    Wrong, THEY LOVE IT HARD.
    ewww, that was a new low for me.
    All Motor.. For Now
    Sanford, NC
    Quote Originally Posted by Seymour222
    and thats why u and him had problems w/ ur cars
    And my top let back never_finished's Avatar
    Oct 2003
    8k
    check your plugs/plugwires dood
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    sounds like ur vtec went bad
    get a new one
    www.turbonator.com
    Hampton, Ga
    your block is cracked and head warped so sell me the car for dirt cheap
    Omicron PERCI 8
    Quote Originally Posted by never_finished
    and your coil pack(s) or distributor cap. I'm not sure which a civic has
    www.fairtax.org
    Quote Originally Posted by kelly
    True. But where's my sig?!! (lol)
    a track near you..
    Werd. I had the same problem once. The higher the RPM, the better it ran. I thought something was really bad wrong. I checked the plugs, and they looked fine. Checked a bunch of other stuff, and couldn't find anything. I decided to check the plugs again. There was a hairline crack in the insulator that goes around the electrode in one of the plugs. Could barely see it. I replaced them, and problem solved. POS bosch platinums.
    Jan 2005
    Columbus, Ga
    headlight fluid, your low
    i know you love my swagger
    OG Black Delegation member
    RIP My Homie Elliot Sloan
    the county
    Scrappy: the car doesn't get dogged. it belongs to my girlfriend and she doesn't like to drive fast so you know. i thought the timing might have skipped, but it doesn't seem to be the case, it doesn't idle abnormal or anything and when i drove it it redlined out like it was suppose to(got smacked in the process for it, too)
    Never_Finished: just had new spark plugs and plug wires put in about 3-4 weeks ago. along with new fuel filter.
    RandomGuy: this car has only see the VTEC once, and it was when i was driving it. and the car was having these problems when she got the car.
    Wurm: you're not getting the car.
    {X}Echo419: i have been told that it could be the distributor cap. i haven't had the time to check it due to i'm at work a lot.(i'm at work now).
    Civic95: same problems here, as the RPM's start to get higher it runs a little better. but its only when you press the gas pedal down so far is when it starts to studdard and shit. but if you press it gently then it'll run fine. but since i just replaced all the plugs and wires, i don't see why it would be them, unless they are fucked up when i bought them from advance.
    B16a2Civic: already check that, cause we all know the headlight fluid is the first sign of any motor problems.
    WEST_SIDE
    i did try to answer your question
    http://forums.importatlanta.com/show...2#post34634782
    BTW did you have a MIL?
    Jan 2005
    Columbus, Ga
    good sense of humor
    anyway, thy are right, it can be afew things, do you after an aftermarket exhaust? check to see fi your cat is clogged, also, timing, alot of times with little to no response for the gas pedal, it could be your timing belt or your tensioner
    the county
    Quote Originally Posted by smoke_Em
    yes you did, but it took so long to find out that much. i need to find out whats up with jessica's car so i know what parts to order for it.
    i am glad to you were able to tell me if the fuel pump was internal or external, cause everyone i asked around here was just like "uh i don't know".
    i don't think its the timing cause the motor was just rebuilt about 2 months ago before it was put into the car. he said he used new parts but i'm still questioning if he did or not.
    MIL?
    Jan 2005
    Columbus, Ga
    Quote Originally Posted by Chink5
    MIL?
    i'd double check, erbuilt motors shouldn't habe ANY problems, oh yeah, what type of fuel and oil are you using....could be that too
    WEST_SIDE
    MIL (malfunction Indicator Lamp) ; check engine light
    the county
    Quote Originally Posted by B16a2 Civic
    oil 10w-40 and gas....that expensive shit.
    the county
    the light isn't on....shows that its running fine.
    WEST_SIDE
    well since you say you rebuilt your engine not to long ago . i would also look at your tranny . assumings it AT? right
    form past experience . some At problem are extremly similsar to mechanical engine problems . just my
    the county
    its a 5-spd
    WEST_SIDE
    brrrrrrrrr . lol good .
    you said you changed your fuel filter, plugs and wires, :confused: make sure everything is tight . and check all your plugs to the sensors tsp, and map especially .they go bad an wont always give you a check engine light.
    a track near you..
    So the engine was rebuilt. Did it run correctly for a period of time after the rebuild? Or has it been like this since the rebuild?
    the county
    Quote Originally Posted by civic95
    it did run good for a while. but i changed the plug wires again and now the engine light is on.
    WEST_SIDE
    what code does it throw?
    get factory honda wires...more trouble come from aftermarket wires. also replace the rotor.
    the county
    changes the wires again and stopped the spuddering...and now it says the VTEC is bad....but i have one of those here for her car.
    Jan 2005
    Columbus, Ga
    ahhh, not gettin good enough spark
    it sounds to be a timming problem change the coil and cap and rotor
    i dont think the v tec just goes bad does it
    BROKE college student
    PHENIX CITY, AL!! (look it up)
    def check the rotor button (aka rotor) inside the distributor cap. My crx wouldn't run one day...we thought it jumped time but that's almost impossible if your timing belt is tight. So yeah, my rotor button would come loose occasionaly and that's probably your problem too. Hope that helps....IM OUT!
