Results 1 to 2 of 2
Thread: FS: Alpine CDA 7863
    Griffin
    Default FS: Alpine CDA 7863
    perfect condition $200
    Alpine CDA-7863
    In-Dash CD Player/Receiver/Ai-Shuttle Controller
    Features
    Tuner
    MaxTune SQ Tuner
    Preset Stations (FM:12/AM:6/DAP:6)
    D.A.P. (Direct Access Preset)
    Auto Memory
    Local/DX Selection
    Preset Address Indicator
    FM Stereo Indicator
    Up/Down Seek
    Stereo/Mono Selection
    Station Title Memory
    Title Search Menu/Scroll
    CD Player
    Music Scan/Repeat
    CD-R Compatibility
    8x Oversampling
    1 Disc DP-S Mechanism
    Digital Servo
    Music Sensor
    Forward/Backward
    Disc Play/Pause
    M.I.X. (Random Play)
    Disc Title Memory
    CD Text, CD Text Display, CD Text Scroll
    Regulated 1-Bit DAC
    CD Shuttle Control
    Music Scan/Repeat
    T.S.M. Scroll (Title Search Menu/Scroll)
    M.I.X. One/All (Random Play One or All)
    Music Sensor (Skip)
    Forward/Backward
    Disc Play/Pause
    Direct Disc Selection
    Disc Title Memory
    T.S.M. (Title Search Menu)
    T.S.M. Scroll (Title Search Menu Scroll)
    CD Text Display/Scroll
    Ai-Net
    External Processor Preset Function Recall
    Ai-Talk Display
    Multi CD Shuttle Control
    General-Head Units
    Selectable Fader
    3-Position HP/LP Crossover (12dB/Oct.)
    Audio Interrupt In
    60W x 4 V-Drive Amplifier
    2 PreOuts
    Versatile Link Ready
    Bass Engine Plus?
    Subwoofer Level Control
    Subwoofer Phase Control
    Bass Center Frequency Control
    Bass Width Adjustment
    Treble Center Frequency Control
    Spectrum Analyzer
    BBE
    Source BBE Memory
    Loudness
    Fader & Balance Controls
    S.T.M.(Source Tone Memory)
    Sound Guide
    Operation Indicator
    Rotary Encoder Volume Knob
    Clock
    Swing Face Mechanism
    Detachable Trim Plate
    Anti-Theft Detachable Front Panel
    Gold-Plated RCA Connectors
    Dimmer-on Lead
    Power Antenna Lead
    Remote-on Lead
    Specifications
    FM Tuner
    Tuning Range- 87.7-107.9 MHz
    Mono Usable Sensitivity- 0.8/9.3 (uV/dBf)
    50dB Quieting Sensitivity- 1.3/13.5 (uV/dBf)
    Alternate Channel Selectivity- 80.0 dB
    Stereo Separation- 45.0 dB
    Capture Ratio- 2.0 dB
    AM Tuner
    Tuning Range- 530-1,710 kHz
    Usable Sensitivity (IEC Standard)- 22.5/27.0 (uV/dBf)
    CD Player
    Wow & Flutter (%WRMS)- B.M.L
    Oversampling- 8X/352.8kHz
    Sampling Rate- 44.1kHz
    DAC Type- Regulated 1-Bit
    Number of DACs- 2
    Frequency Response- 5-20k ?1 dB
    Total Harmonic Distortion (THD)- 0.008%
    Dynamic Range (1kHz)- 95 dB
    Signal-to-Noise (S/N)- 105 dB
    Channel Separation (1kHz)- 85 dB
    Crossover
    High Pass Crossover Frequency- Off/80Hz/120Hz/180Hz
    Low Pass Crossover Frequency- Off/180Hz/120Hz/80Hz
    Crossover Slope- 12 dB/Octave
    Crossover Type- Analog
    Remote Control
    Model Number- RUE-4185
    Battery- 2 x OAAAO
    General-Head Units
    Bass Control Range at 60Hz- ?15 dB
    Bass Center Frequency Selection- 60Hz, 70Hz, 80Hz, 90Hz, 100Hz, 130Hz, 150Hz, 180Hz
    Subwoofer Level Control Range- 0 To ?15dB
    Treble Center Frequency Selection- 10kHz, 12.5kHz, 15kHz, 17.5kHz
    Chassis Size (W x H x D)in- 7Ox2Ox6-1/8O
    Pre Output Voltage (Before Clipping)- 2 V
    Treble Control Range at 10kHz- ?10 dB
    Operating Temperature (!C/!F)- 60!C (140!F) to -10!C (14!F)
    Power Requirement- 14.4(11-16) V.DC
    Maximum Mounting Angle- 30! from Horizontal
    Chassis Size (W x H x D)mm- 178mm x 50mm x 155mm
    Nose Piece Size (W x H x D)mm- 170mm x 46mm x 19 mm
    Weight- 1.5kg (3lbs. 5 oz)
    Maximum Power Output (Note 1)- 60Wx4
    Continous Power Output (Note 2)- 27Wx4
    Nose Piece Size (W x H x D)in- 6-3/4O x 1-13/16O x 3/4O
    Note 1: Under maximum operating voltage and input signal, into 4 ohm loads-
    Note 2: Per EIA-517 standard, 40Hz to 20Hz, 0.8%THD, with 14.4 volt DC Supply-
    Griffin
    sold
