Thread: how long does it take for my spring to get lower????
    Default how long does it take for my spring to get lower????
    ok i got sum new suspention techqueit spring for my 96 prelude. after i put them on, the rear got lower in a few days, but the front is still siting at the same height. do i did suming wrong or wat????????
    My Spoon Is Too Big! Flip's Avatar
    did it say how much the apx. drop height for those springs was? It shouldn't take more than a day or two at MOST...
    BMW_VW D_Land.rep!! EX-Svic's Avatar
    did you by any chance put the ones for the rear in the front.
    lift up the car with a hydralic jack and drop it at a moderate speed , that might work , worked for me....
    Roswell, GA / Georgia Tech
    mine took around a day, weird.
    Oviedo, FL
    Quote Originally Posted by khoip88
    Are you using coil-overs? And if so, did you tighten them down afterwards?
    :-/ just a thought
    Senior Member mikesEK's Avatar
    over yonder
    jack the car up and look to make sure the ones in the front are the larger spring ,,meaning the circumfrence<<<hope i spelled that right,,,, of the spring NOT how tall it is ,the fatter springs belong on the front,,but if u got em bassakwards you would know cuz the front would be hammered and the rear would be jacked up pretty high
    PawnShopMike
    I miss-spell big words freeqwentlee thanks Dekalb Co skhool systems
    All Motor EK N/A EK's Avatar
    On IA.com
    You probably did something wrong...cuz mine dropped after i took it for a test drive.
