Thread: Blinkers wont work after dash install??
    Default Blinkers wont work after dash install??
    I just did a dash swap into my 95 civic coupe ex 5 speed. Everything is working so far except the blinkers, they wont do anything with the directional. The hazard button is hooked up and the blinkers work with the hazards on. Im sure it's something that i am over looking.. Anyone else have any suggestions or been through this please let me know thanks.
    Just low on titanium. That's all. Later, QD.
    Certified Gearhead SLR's Avatar
    Northeast Alabama
    i believe the turn signals are wired through the hazard switch, so if the blinkers work with the hazard is pressed, your wiring down there is wrong. i've worked on a lot of cars where the wiring was messed up and it would blow a fuse every so often. check em... follow your wiring and make sure everything is kosher.
    KEITH atlvi3tb0i's Avatar
    Clayton County
    most of the time the power is run thought the radio
    Quote Originally Posted by atlvi3tb0i
    I thought about that, so i connected the radio and still nothing. I would think if a fuse was blown then the hazards or some lights or something else wouldn't work either. Im going to try and get a schematic tomorrow and go over it.
    u need to change ur blinker fluid lol j/k
    :noitacoL
    PROBLEM SOLVED!!!!!!!!!!!!!
    There is a 3 prong clip that goes into the blinker side of the steering column, just above the main clip that goes into that side... That 3 prong clip was clipped into the windsheild wiper side of the column which also has a spot for a 3 prong clip, but apparently that side isn't suppose to have one.. because everything works once i swapped that clip to the other side.
