Results 1 to 3 of 3
Thread: NGK AFX Wideband
    The man you want to be Lucient's Avatar
    Snellville
    Default NGK AFX Wideband
    Ok I purchased on of these from Ballenger Motorsports last week(bmotorsports.com) and I must say that it is a well put together kit and very easy to install. I installed it in about 30 minute(I already had a bung welded in my downpipe). If you dont happen to have an extra bung one comes in the kit. The only wiring is the power and ground wires to the unit. I ran the wire ti the sensor through the front driver side fender and behind the fuse box under the dash.
    First impression: Works just great after calibrated. make sure you know exactly where you want the display mounted before you calibrate the sensor. Calibration is very simple. Display is very bright and you can see it clearly day or night.
    Price was $240 which is great and it uses the Bosch or NGK sensors. It was a great purchase.
    Ballenger motorsports shipped the item quick and they were very friendly and returned all my emails promptly.
    Blooregard Q. Kazoo turbosx©'s Avatar
    femalesaplenty
    does it included the sensor?
    I got dinner to goto.
    Snellville
    Yep Includes the sensor
