Thread: b18c1 no vtec
    khmer empire foo!!
    kampuchea
    Default b18c1 no vtec
    I need help? my gsr doesn't have vtec. I change the oil pressure switch and the vtec sol. Check the wiring and still no vtec. If anybody knows, please help me. thanks.
    __DailyGrind
    VTAK!!!!!!!!!! FTW!!!!!!!!!!
    your moms house
    i heard that knock sensor would cause it. you throwing any CEL codes??
    FUCK B&D COMMUNICATIONS!
    khmer empire foo!!
    kampuchea
    when it first start, there's no cel. Know sensor is good. I have a vtec controller also and it say's vtec input and output on but i don't here vtec. When i drive it to 7000 and above once, the cel pops up and it read vtec oil pressure switch. I change to a working one and check the wiring and still no vtec, and also the vtec input goes away but vtec output say's on but redline at 6500 which i have no vtec.
    your moms house
    wait so fuel cut is 6500??
    My Spoon Is Too Big! Flip's Avatar
    do you have enough oil in it? heh don't mean to be ... whatever you call it.... but some people over look that. If your oil pressure is not high enough it won't kick in.
    your moms house
    true true or oil pump could be fucked
    There is a Plug in the front of the Head... Get a Oil pressure gauge and connect it there... Should be over 50 Psi At the Point Vtec would ingauge
    Try that and Post what Oil Pressure you have...
    To 942JZGTE 93H22ACX's Avatar
    try wiring back the VTM wire on the VTEC controller back to stock. so leave all the wires from the vtec controller how you have it connected but disconnect the VTM wire from the VTEC controller and rewire the VTM wire back how honda had it.
    4-5 years ago i had APEXI VTEC controller and for some reason if the VTM wire is hooked up the car would not hit vtec.
    try it and let us know
    94 Supra= 500rwhp
