Results 1 to 27 of 27
Thread: msd dis2
    Default attention rsx and k20 24 owners msd dis2
    i have a dis2 ignition box that i need to sell today
    sold sold sold please delete
    Improved output from late model distributorless ignitions.
    Improve the output of your late model, distributorless ignition system (DIS) with MSD's DIS-2 Plus digital ignitions. The capacitive discharge ignitions feature multi-channel capability, complemented with multiple sparks, two rev limiters, and a timing control. These DIS ignitions are engineered with the latest in digital science, including power MOSFET technology and efficient IGBT coil drivers. They're managed by a 15 MHz micro-controller for extremely fast compensations and decisions. In the end, this creates incredibly accurate spark delivery, rev limiting, and timing functions. Throttle response and mid-range pull are also improved, due to a series of powerful multiple sparks that last for 20 degrees of crankshaft rotation. There is a two-step rev limiter, which gives you one limit to set for holeshots and another for top-end performance. For engines using nitrous or extremely high cylinder pressures, you can also program a high-speed retard after the engine hits total timing. Both of these features are easy to adjust with the new built-in rotary dials. They also feature an ignition interrupt that will prevent the engine from starting by disabling the output to the coil, a retard feature that retards the timing at the top end to prevent detonation, and an LED monitor that will alert you of a low supply of voltage or faulty input signals. Also, there is now a true step retard that can be activated through your nitrous solenoid wiring! The DIS-2 Plus ignitions are designed for 4-cylinder engines with two coil packs.
    it cost 450 new ill sell it for 100 bucks asap
    function KBPopup(strUrl) { var newWin = window.open(strUrl, "KnowledgeWin", "width=425,height=250,resizable=no,scrollbars=yes, toolbar=no"); };
    what does it do. Tell me in small words.
    it makes multipul sparks at low rpms for beter throttle response and better idle and makes a beter spark all the way throgh the rpm range for better combustion and more power it cost 450 buck i just got to sell it to tow my crx
    new used?
    it is used but in perfect condition
    How long?
    very little the guy recked his car like a week after he put it on
    Oh, so you didn't even install it in yours?
    Should gains be expected? If so, what kind?
    dont u have a newer civic si like the hatch with k 20
    no i havnt installed it but im not sure how much gains but the throttle response is suposed to be exellent
    but yes some gains in power
    turn ur away message off on aim and ill im u
    the price is neg lmk
    obo lmk
    any boby lmk asap
    bump for a good deal that needs to be sold today
    need to sell bump
    Atlanta Suburb
    does it comes with manual and everything?
    pm me your number i'm interested.
    no it dont have the manual but it has almost all the info on the back of it
    sale pending tonite
    sold sold sold sold
    goodie
    Someone call my lawyer... slyde_wayz's Avatar
    D.S.G.
    I want it. 678-463-2016
    its sold sorry
    Quote Originally Posted by slyde_wayz
    Atlanta Suburb
    it's mine.. i dont know if it's work but we'll see...
