Results 1 to 5 of 5
Thread: ls/gsr head swap
    J-Remy smoking RR's Avatar
    ATL BABY!
    Default ls/gsr head swap
    ok, i need some help people, i am getting ready to do an ls to gsr head swap and have a few questions. i have an 98 integra and need to know if my ecu and distributer will work with the new head. i have heard it will work from some people and that it wont from others. please let me know what the low down is. thanks!!
    Hump Her Crew Member
    Boobie Sharing Co. founder (A.K.A. B.S.C.)
    ATL BABY!
    any one out there?
    DC5-R
    Gwinett
    well if you're talkin about doing a ls/vtec then you might want to change out the ECU seeing how you'll need vtec and a couple of other things to work. A p72 should solve that if not then just get a obd-2b to obd-1 conversion harness. As for the dizzy, no it won't work, you will need a vtec dizzy.
    NorthSide
    here's a ls/vtec parts guide you would want to check out. i did my reasearch and decided not to do the swap, so i'm passing it on to you~
    http://www.c-speedracing.com/howto/lsvtec/parts.php
    hope to hear from ya soon jeremy!
    port flow and 3/5 angle valve job ftw!
    ATL BABY!
    [QUOTE=BLk92DA]here's a ls/vtec parts guide you would want to check out. i did my reasearch and decided not to do the swap, so i'm passing it on to you~
    QUOTE]
    thanks, i will check that out in a few and see what i come up with
