Results 1 to 40 of 64
Thread: FS: JL 12w3v2-d4 SUB, Kenwood Amp, 1.5 cap & install kit
    Dacula GA
    Default FS: JL 12w3v2-d4 SUB, Kenwood Amp, 1.5 cap & install kit
    What I have here is my system that was going to be put in my accord. I dont really know if I wanna put it in there now. I pulled the wire kit out, started to pre cut some things, then said fuck it all. Nothing has been used, all new with 0 hours of play time. The sub was taken out of the box and installed in the HiFi Buys box it is in now. The prices are bellow along with all the model numbers of everything. THANKS
    12W3V2-D4- $175 obo
    Specifications:
    Nominal Diameter 12" (300 mm)
    Continuous Power Handling 300 Watts
    Voice Coil 2.25" diameter, 4-layer, Kapton former
    Available Configurations Dual 2 ohm, Dual 4 ohm or Dual 6 ohm
    Xmax (one-way, linear): 0.46"-0.51" (11.7-13.0 mm) depending on specific model
    Sealed Enclosure Range 1.00-1.50 cu.ft. (28.3-42.0 liters)
    Ported Enclosure Range 2.00-3.00 cu.ft. (57.0-85.0 liters)
    VCR Technology Yes
    Elevated Frame Technology Yes
    KENWOOD KAC-8152D- $175 obo
    Features
    * Ultra Efficient Class D Circuitry
    * MOSFET Power Supply
    * Torroidal Noise Suppression Filter
    * Copper EE Core Power Transformer
    * Dual Secondary Capacitors
    * Ground Isolation Input Circuit
    * Detachable Aluminum Dress Plate & Top Panel Control
    * Die-Cast Aluminum Heat Sink
    * Variable (50 - 200 Hz) 18 dB / Octave Low-Pass Crossover
    * Switchable (Off / 15 / 25 Hz) 18 dB / Octave Subsonic Filter
    * Gold-Plated Preamp Inputs and Outputs
    * High and Low Level Inputs
    * 2 Ohms Mono Stable
    * Red Triangle Power Indicator
    * Gold-Plated Screw-Type Power and Speaker Terminals
    * Variable (0 - 18 dB) Bass Boost at 90 Hz
    * Single-Side Terminal Placement for Cleaner Installation and Improved Wire Management
    Subwoofer Mono Amp Specifications
    * Amplifier Type: Mono
    * RMS Power @ 4 Ohms: 300W x 1 @ 4 ohms
    * THD at 4-Ohm RMS Power: 0.08%
    * Bridged RMS Power @ 4 Ohms: 550W x 1 @ 2 ohms
    * Speaker Level Inputs: yes
    * Preamp Outputs : yes
    * Built-In Crossovers: LP
    * Bass Boost: 0 - 18 dB
    * Frequency Response: 5-200 Hz
    * Signal to Noise Ratio: 100 dB
    * Dimensions: n/a
    Whip Audio 1.5 Farad Cap- $50 obo
    24DCV surge with digital read out screen
    Universal install kit with fuse- $30 obo
    just your normal install kit with 4 guage wire
    DB Link Hi-Lo Converter- $10 obo
    connects to your car speaker wires and allows you to hook the system up to a car with no rca ports on the radio, great for stock radio cars.
    TOTAL $440 for eveything. I will take $400 if someone wants in all. THANKS
    Dacula GA
    Morning bump. Not in any hurry to sell...
    ^ Has way toooo much pr0n v3rd1g0's Avatar
    Marietta/Lawrenceville
    bump for a good guy. if i had the money i'd take this off ur hands but my cars been in and out of the shop so i'm broke haha. good luck BUY HIS STUFF EVERYONe!!
    No siggy as of right now
    where you located
    Dacula GA
    snellville/lawrenceville area
    Fuk Who U B!
    Northside B
    How much for just the AMP and SUB??? LEt e know!
    Dacula GA
    pm'd
    Fuk Who U B!
    Northside B
    300 cash!!! Let me know!
    Dacula GA
    $325 for the sub and amp with the box. no lower, sorry if I sound like a dick, but I am already loosing money on something I never used. If I do not sell everything, I will just re-use it after the car gets painted
    Dacula GA
    bump for today
    Dacula GA
    bump for the night
    Dacula GA
    athens
    what's the rms watts on the amp? Just sell the amp?
    Dacula GA
    RMS Power Output: 300 W
    Peak Power Output: 1100 W
    With the setup I was going to run at 4 ohms it was pretty much a 550 watt system
    Dacula GA
    175$ OBO PM me with offer
    Suwanee/Dahlonega/ Miami Beach
    how much for just the sub?
    Dacula GA
    $175 obo PM me an offer and we can see what we can do. The sub comes with original box and paperwork
    Dacula GA
    Dacula GA
    Dacula GA
    BUMP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Dacula GA
    BUMP for a new day
    Dacula GA
    bump for the night time. Im up for trades for entire system
    Dacula GA
    Dacula GA
    Dacula GA
    Dacula GA
    Fuk Who U B!
    Northside B
    Bump for some nice subs, Someone buy this shit!
    RPM master high revvin''s Avatar
    C.ount O.n B.ieng B.usted
    got a 10 gig ipod i'll trade for the amp. will you take 65 for wiring kit and cap?
    Gear Second atlxkevinx's Avatar
    Suwanee & Perimeter
    175$ for sub with box? or no box?
    2007 E92 335i Coupe | Space Gray | Coral Red | Sport | Cold Weather | Navi | iDrive | Logic7 | AAIC
    Dacula GA
    with the box, it was from HiFi Buys if it makes any differance
    Dacula GA
    Dacula GA
    Dacula GA
    bump.....need money for car payment!!!!!!!!!
    athens
    ill give u 40 for the cap?
    Dacula GA
    $50 is way below what its worth. if you go to Hi Fi Buys, Circuit City, or any other place and try to get a 1.5 Cap it will be over $75. $50 is more than fair
    athens
    sonicelectronix has a 5 farad for 85!
    Dacula GA
    well shit...hit them up. thats more than you will ever need unless your running like 5000 watts....lol
    athens
    u dont ever really need a cap just to let you know. a person on another forum said it best using a cap for extra power is like putting a bandade on a bullet wound not much help. i just want 1 to have the complete setup. all you had to say was no thankz man i thought you needed the money i mean hell you have bumped it up enough times to indicate that!
    Dacula GA
    ya I have. I will keep the system for the vette if I dont sell it. But if I do sell it I am going to sell it at a little less than what I paid. Its only $400 total, it not even a car payment so I will not really need to sell it. Just though since the car had a system already that I would keep it, but JL is always better than Alpine
    athens
    true
