Results 1 to 15 of 15
Thread: E85 Ethanol
    Patience Pays...
    Default E85 Ethanol
    Has an 100-105 octane rating.. so my question is why arent more turbo'd cars running off of this stuff?
    Here and there Hulud's Avatar
    Omnipresent
    whats the price of it?
    Val for President
    livin again collins's Avatar
    chillin in the sloooo gtoooo
    cheaper than gas!
    like ALOT cheaper
    Patience Pays...
    I hear its about $2/gal in Chicago.. and their gas prices are a little higher than ours the last time I was there.
    yeah thats awesome! didnt know about the octane rating tho! that kicks ass!
    A.K.A. GA Teg
    Jun 2001
    Behind the lens
    Man I would run that in the civic. Not for performance, only cause its cheaper.
    www.ATLphoto.net Myspace
    <3 boost
    welcome, NC
    it may be similar to toulene, has good octane rating and price, but is dangerous to handle and will fuck some stuff up if its not made for it
    93 turbo mr2
    99 buell S3
    Hampton, Ga
    hydrogen ftw
    Rotary Man redlinenprelude's Avatar
    lilburn/snellville
    its made from corn..
    Patience Pays...
    Quote Originally Posted by ECMgarrett
    All it really is is a very potent moonshine, wonder does that mean you can make it at home? Did a little research and found that Ethanol has about 69% of the energy output that regular gasoline has BUT pure ethanol has an octane rating of about 110. Interesting stuff..
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    is this that flexfuel stuff that some GM vehicles were made for? if so i think that the fuel system has to have some sort of special seals that are resistant to the properties of the ethanol, and something about it takes a lot more of it (like the injectors have to flow a lot more) than for gas to run properly...if this isn't the same stuff oops.
    Who knows?
    lilburn/snellville
    85% ethanol and 15% gas.
    lilburn/snellville
    between 100 and 105 octane rating.
    Patience Pays...
    Quote Originally Posted by hondabuilder
    That is exactly it, in Brazil I believe it is Ethanol is just as common as regular gasoline and GM makes 90% of their cars compatible there. It does require bigger injectors and on some older cars it wouldn't work at all (which pertains to the seals you are talking about with the fuel system)
    Still Here LQQKITZME's Avatar
    Roswell
    Fords and dodge's can run it too
    Taurus has been ffv since 96 this is old skool tech
