Thread: Prelude Unorthodox Pulleys
    Default Prelude Unorthodox Pulleys
    'sup
    I plan on purchasing an unorthodox Pulley Kit.
    http://www.unorthodoxracing.com/Merc...preludeultraSS
    Saw the kit didn't come with belts. I'm a beginer when it comes to motor work. I saw when i downloaded the instructions the sizes of the belts i need, anyone know where i can get the belts and how much they cost?
    thanks for any help!
    -tek
    SOUTHERN SPEED
    macon ga
    about ten dollars a piece at any autozone are advance auto parts.
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    I have to replace the belts? their different in size from the factory belts? or can i use the same belts?
    I have them on my H22 let me check the size and i will send them to you.
    About to approach beast mode
    allright appreciate the help
    altenator, ac, crank belt- 37-6(in red letters)
    25-060410 (this belt came from napa auto parts)
    power steering pulley- Mitsubishi 56992-P13-0030
    4PK1020
    R34-7KC (not sure where this belt came from, whooever sells mitsubishi belts will have it or can order it)
    I'd be very leary of any pully kit that replaces the stock crankshaft pulley. The stocker is a perfectly engineered weight and size, it assists greatly in dampening engine vibrations. By replacing it you'll basically put your engine to an early grave.. it will vibrate itself apart and eventually damage the bearings
    I have had my on for 3+ yrs as of today and i run my motor hard, i have had not one single problem. No weird vibrations or anything like that, she purrs like a pit.
    Had them installed at OPM a few months ago.
    Car is still running fine even ran it hard a few times.
    They are AWESOME and so far no problems yet.
    Thanks for the info!
