Thread: e30 325i
    bavarian motorsports FTW!
    where ever theres food
    Default e30 325i
    im looking to swap the tranny in my 325i to a 5speed just wondering if i find a donor car what kinda trouble im looking at?
    also my friend told me i need a mass air conversion but im lost on what he means is it just a intake or is it a whole new setup
    "The M3 engine does not develop it's power ... it is simply present in an overwhelming quantity at any time. "
    AutoZeitung 1992
    e30 fuh raze
    gainesville, ga
    It is not very difficult. I have done two clutch changes on my 5spd. You will need to put together extensions and ujoints to get to the top tranny bolts. As far as what you will need for the 5spd swap, tranny, shifter assembly, pedal assembly, clutch pressure plate flywheel, driveshaft, tranny crossmember, and a few other things. Go over to e30tech.com or r3vlimited.com and do some searching. One of the members would probably put you a swap kit together for around $500. You can also go to Strictly German in braselton, couple miles past Road Atlanta. They will have everything you need in stock. They sometimes quote shitty prices on the phone but if you go with cash they'll give you a good deal. I'm sure he'd put you a used kit together for around $500.
    Cruzan Boy Siverprobegt's Avatar
    ga/VI BREED
    I like the pic of ur bmw(Bad Man Wagon).I've always like that model!!
    92 mx3
    Lawrenceville, GA
    mass air flow conversion? maybe you mean a mass air flow meter? go with the stock one. ask for bobby at strictly german. he knows all about bimmers. i tried to do a 535 MAF (mass air flow) swap but it didnt work so just go with the stock one. bobby will hook you up with everything you need for the tranny stuff
    how well does the stock meter flow? since it has the throttle position sensor trap door, it looks like it wouldn't flow very well.
    Lawrenceville, GA
    its not bad... could be better but w/e. im doin an engine swap soon so im not worried about it at the moment
    Quote Originally Posted by non2os13
    The problem isnt flow so much.. its the contacts on the sensor.. and the return spring. After almost 20 years they get corroded and weak. There are conversion kits to convert AFM to MAF.. But they tend to be VERY expensive.
    thanks alot for all your help guys im about to start making some real money at my new job so first on the list cure my car from running sick (i got a vacuum leak) its killing my power then on to the five speed
    AutoZeitung 1992
