View Poll Results: B20 or LS
Voters
174. You may not vote on this poll
  • B20 w/o vtec head
    123 70.69%
  • LS w/o vtec head
    51 29.31%
Results 1 to 40 of 56
Thread: LS vs B20 (non-vtec)
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Default LS vs B20 (non-vtec)
    Well, I'm tired of my lil d16a6 in my crx, so it's about time for a upgrade. So my question is what would be a better swap, LS or a B20 (non vtec now). Keep in mind that all I'm going to do is add a few bolt-ons to it (no nos, turbo, or sc). So I don't want to hear about the sleeves of the B20. I just want to get some feedback about the two engines. Thanks for your help.
    livin again collins's Avatar
    chillin in the sloooo gtoooo
    b20 all the way man. i had the b18b factory in the teg, blew it up, and dropped the b20. i must say it pulls alot harder. for basically the same money, do the b20. its got ALOT more tq, AND is just as tuner friendly as the ls.
    FI=LS, anything else B20... B20 with an LS IM and some LS cams make for a very awsome stock swap...especialy in a CRX
    ECEFC.com
    Thanks for the replies, still looking for more opinions!!!
    Decepticons Apache's Avatar
    What is the car going to be designed 4?(Autocross,drag or etc)
    Duppy Rider
    the county
    Quote Originally Posted by collins
    b20 all the way man. i must say it pulls alot harder.
    ECEFC.com
    Quote Originally Posted by Apache
    daily driver
    Banned LS2ner's Avatar
    The Face
    b20 if all ur doing is bolt ons.
    Trap'Ville
    how much b20 run for wat tranny are u going to be using?
    DC5-R
    Gwinett
    b20 longblock is about 500-600, and I hope you're going to be using a gsr tranny on it
    i'm just using my factory ls tranny for now, simply because i love the taller gearing. the car's not going to be phenominal in acceleration, so give it more top end, and you're set for some nice hwy cruising.
    Straight O.G. BlackEj6's Avatar
    StockBridge
    I would go B20..I think its has like 6 more lbs of tq than the ls and around the same HP..,,Oh yea..The Sidekick Works lovley and I picked up aRex my self..Its under construction so I can sell it..
    Cruzan Boy Siverprobegt's Avatar
    ga/VI BREED
    B20 ,my friend got 1 in his teg and it runs very good.
    92 mx3
    Banned OnSite's Avatar
    b20-typer r bitches
    WEST_SIDE
    b18b . thats jsut me
    Getting there admedlin's Avatar
    Columbus
    Quote Originally Posted by Siverprobegt
    exactly. I have a friend running a B20 in his CRX, very quick
    ga/VI BREED
    Do the b20 and b18 have the same cams or the ls cams is a little bit better????
    92 mx3
    Master of the G2 Integra cardesignz's Avatar
    Cumming/Alpharetta, GA
    You have B18A's, B18B's, USDM B20B's (8.8:1 comp), USDM B20Z's(9.6:1 comp), JDM B20B's (8.8:1, 9.2:1, and 9.6:1 comp). The high compression JDM and the B20Z definitely have a little better cams than the lower compression ones and the B18's, but I think that most of the rest of them are all about the same.
    Here is a ton of useful info on the B20:
    http://www.tuneruniversity.com/forum...ead.php?t=1900
    1989 Toyota Supra fossil413's Avatar
    where can i find a 20b for a good price
    ga/VI BREED
    My friends jdm b20,has no knock sensors,but it came with a p75 intake manifold..Which one did he get?????
    92 mx3
    Certified Gearhead dwnsthGABOY's Avatar
    Dec 2003
    Amsterdam, Netherlands
    passwordjdm.com
    Quote Originally Posted by admin
    whatever dude? 1,000,000 says you suck my dick while Fox News reports it
    IA's Transformer God obd1kenobi's Avatar
    29th Chamber
    Are the B20 and B18b Heads the Same??
    GeckoSquad / Skull Platoon
    Except for the rare P8R head that came on some of the JDM B20B's, all of them have the P75 head which also came on the 96+ B18B.
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    what is the redline on a b20. I don't think they are the same
    To answer your question, my B20Z2 redlines @ about 6800.
    Now to properly end any debate and confusion over the capabilty of the B20 vs. and LS, mine has 146whp/137tq with just i/h/e after a dyno tune at mainstream. I am pretty sure I had some bad gas in the tank and I know it had some cheap oil in it and only 80 miles on the swap, so it could definitly be putting out a little more at this point and 150+whp should be attainable with just bolting on a high flow cat (if it is not already putting that out). If you want cheap power without dealing with vtec, go to car-part.com and shop around the local salvage yards for a 1999-2001 Honda CR-V engine (this is the B20Z like I have and the B20 to get). I paid $850 for mine after tax, which is about what you would pay for a JDM B20B, which usually turn out to be the low compression engine that is basically only useful for a turbo in my opinion (they should technically feel about like a b18, just with a little more torque if that is all you are looking for).
    stats from Honda in the CR-V:
    1996-1998 USDM B20B/JDM B20B 126hp/133tq 8.8:1 CR
    1999-2001 USDM B20Z/JDM B20B 146hp/133tq 9.6:1 CR
    As can be seen from my results, when properly tuned, there is no debate. B20's rule.
    Da "A" Niccuh
    what did you tune you car with. (uberdata,SFAC,ETC) just curious
    It was tuned with Chrome. Scotty at Mainstream chipped and socketed my stock OBD1 ECU and then he tuned it on the dyno. I forgot to mention I'm getting a consistant 32mpg with it in my 1992 Integra with my very agressive driving and it passed emissions after he re-enabled the O2 sensor LOL.
    Sleeper.
    Quote Originally Posted by cardesignz
    Not all b20's come out of a CR-V There like 5 or 6 diff kinds... Which month/year is yours?
    JDM b20b Non VTEC. Yet that is...
    If you had read, you would have seen that mine is a B20Z, which only comes in the 1999-2001 USDM Honda CR-V, specifically, mine is a B20Z2 from a 2001. All USDM B20's come out of CR-V's. Yes, besides in the CR-V, they are also found in various Honda station wagons in Japan (orthia, stepwagon, etc) which get various hp/tq ratings from Honda due to various fuel maps, intakes, and exhaust manifolds. They are all also labeled as B20B, so if you are getting a JDM engine, you really have no idea what you are getting without some thorough research/documentation - most of the ones they are bringing over are the low compression ones. The only one of them that should differ from the the USDM B20B's and B20Z's specs is the JDM one that has the P8R head (larger vtec sized valves) instead of the P75. It also has an LS style intake manifold and has 9.2:1 CR due to a thinner head gasket (still has the low compression pistons and the same cams as a USDM B20B). This one came in the different wagons only in certain years. That's why I mentioned going to a local salvage yard and getting a 1999-2001 B20Z, so that you know that you are getting the good one. JDM engines are a complete gamble - the only way to identify the high compression one is by the knock sensor (all of the ones with the same specs as the b20z should have one - I am told that is is green on the JDM engines - my USDM engine had a brown one on the back of the block under the IM). So, which one do you have?
    Some of the best B20 info that I have found is located here:
    IA Member souldigger's Avatar
    Tucker, GA
    B20 gets my vote.
    I JUST DONT GIVE A FUK dereksi's Avatar
    Quote Originally Posted by fossil413
    20b?
    YEA...IM AN ASSHOLE
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    Didn't the 3rd gen preludes have B20's???????
    Quote Originally Posted by fastboyamin
    B20A = nothing like any of the other B-series engines.
    http://en.wikipedia.org/wiki/Honda_B20A_engine
    WHEREMYBITCHES dowhatido's Avatar
    lost
    question???? if your not going to go turbo, why wouldnt you run a vtec head. suggestion-(and this is completly open) b20 w/b18c5 head decked, with built internals
    high comp......if not going turbo
    bong rips prefered!
    RIP 94 ej1/b18c1
    welcome rebirth of 93 eg/b18c1
    29th Chamber
    Im building a head to throw on a B20 Block, then going to throw a JRS on that bitch, it should be fun!
    B18c1
    woodstock
    B20 all the way...
    Senior Member Slowboy's Avatar
    Savannah, GA
    I want a b20 in my rex, But then again. i dont know. geez i hate honda's
    :boobies:
    Shooting mutha fuckahs in the face and gettin paid.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    for daily driven torque and power get a higher compression b20z as will the add ons such as a header intake and so forth will help much more in tha long run. b20b for performance upgrades like turbos and chargers up to 8 psi only as far as everyday driver. mine was done by scotty at mainstream and is on 8psi but has a b20b bottom with gsr haed and cams and puts down 260whp and is 4 years old.
    hmm b20 with LS camshafts, LS IM and a gravy b16 tranny on it ooWee, you'll maxx out at 125mph hittn the red limiter (tested and approve)
    /Oo ___A___ oO\
    |=_/_______\_=|
