Results 1 to 28 of 28
Thread: FS: short shifter, tires, civic parts, and more
    Senior Member Schugg's Avatar
    Default FS: short shifter, tires, civic parts, and more
    TIRES/RIMS/CENTER CAPS
    Four 4 aftermarket rims 4lug pattern - one rim has a small crack on the inner edge, and one is curbed pretty bad. $70.00 OBO
    Two sets of stock honda center caps - came off 95 coupe model one set is all chrome, one is black in the circle with chrome H$8.00 each OBO
    Two 195/65/15 Yokohama AS430 tires - by look i would say about 7 32nd's on the tread, but not sure. $15.00 OBO
    16 wheel Lug nuts - all i know is they fit 96 volkwagen jettas $10.00 OBO
    Four 14 inch steelies with center caps, and no tires - $25.00 OBO for all four
    One Kuhmo Ecsta HP4 195/60/14 tire - $8 OBO
    One Mastercraft Avenger LSR 195/60/14 tire - $8 OBO
    OTHER STUFF
    Windshield wiper lever came off a 95 civic coupe ex $5.00 OBO
    Automatic cluster - from 94 civic, has all insides, gas gauge pin is broken $5.00 OBO
    tag box with light moldings - came off 95 coupe $3.00 OBO
    Bottom back seat cushion - one cigarette burn, from 95 civic coupe. $5.00 OBO
    d16z6 Power steering pump - $10.00 OBO
    d16z6 block and all internals - block was knocking when taken out and apart (block code: 464D88D) $15.00 OBO
    D16z6 oil pan - no drain plug, pretty good condition$10.00 OBO
    both rear brake drums and assembly - 95 civic coupe brake drum assembly, have good amount of pad left on them also $15.00 OBO
    96-98 honda civic headlights - $50.00 OBO
    B20 Valve cover - $15.00 OBO
    B20 Throttle body - $30.00 OBO
    B20 Idol Control Valve - $25.00 OBO
    B20 Fuel Rail and injectors - think thats what it is, look at picture $20 OBO
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    Turbo City USA
    d16z6 alternator - $20.00 OBO
    d16z6 AC compressor - $25.00 OBO
    I got $40 for those
    need them asap!!
    San Antonio, TX
    did you still want that guage for $10?
    twoONEoh
    Quote Originally Posted by Skinny
    I got $40 for those
    need them asap!!
    PM is about to be sent
    - 2008 Acura TL-S
    Quote Originally Posted by Cremepuff
    yah probably if its the ex one, with both the gas and temp levels on it.
    - 2008 Acura TL-S
    Athens/ATL
    I'll take that z6 block/internals/oil pan.. PM me so we can meet up.
    Good prices man
    Quote Originally Posted by xPhantomSolx
    pm sent
    - 2008 Acura TL-S
    bump, updated things that have plans to be sold
    - 2008 Acura TL-S
    See if the SS fits an 88 crx
    ill try to find out, its new never used. i was sent the wrong shifter and tried to make it fit. only reason it wouldnt was the ball that holds it in the rubber/plastic housing thing, was smaller than the one made for it, so it would just slip down out of it. if you can tell me what size the ball is on your shifter ill tell you if this one is the same and it should be fine. but ill look around to see what else it might fit.
    - 2008 Acura TL-S
    doesnt look like it will fit an 88 those all have different part numbers
    - 2008 Acura TL-S
    Turbo City USA
    Thanks again! Buy this guys' stuff
    haha thanks
    - 2008 Acura TL-S
    San Antonio, TX
    are you going to the V? i'll have the cluster with me
    twoONEoh
    probably wont be going there, i never goto meets.
    - 2008 Acura TL-S
    southside ATL
    still got the block??/ pm me
    BABIES "R" US crew
    about to PM you.
    - 2008 Acura TL-S
    San Antonio, TX
    aiite, well let me know whats good with you.. its in my car
    twoONEoh
    added some things, bump
    - 2008 Acura TL-S
    Dec 2003
    U have PM
    - 2008 Acura TL-S
    bump it up
    - 2008 Acura TL-S
    Banned 4U2NV_FLC's Avatar
    Mall of GA Area
    SHORT SHIFTER? FEENIN!
    Athens/ATL
    Hey idiot n00b... way to bump an 8 month old thread.
    this is gheyfer IBTL
    Banned caseyT's Avatar
    Winder
    info on headlights
