Results 1 to 4 of 4
Thread: ls vtec and b20 vtec questions!!??
    Unknown
    Exclamation ls vtec and b20 vtec questions!!??
    I have a del sol that has the jdm d15b vtec motor in it and i want to replace it with either a ls vtec or b20 vtec, but i need to know witch is the better combination, because i have heard that ls and b20 blocks weren't that strong, and i am andting to boost the engine. does anyone know which is better and can get higher horsepower levels?And does anyone have a ls or b20 block for sale?
    Senior Member BlkCD5's Avatar
    Well, with the B20 you have a bit more torque, but plan on upgrading the internals and resleeve it if you boost it.
    Cruzan Boy Siverprobegt's Avatar
    ga/VI BREED
    would a b20 ,with a b16 head(no rods or piston upgrade) hold up,or it will throw a rod,etc, after some time..
    92 mx3
    Banned LS2ner's Avatar
    The Face
    Quote Originally Posted by Siverprobegt
    You have no idea what ur talking about. this is the wrong forum for this post anyways. The b20 block has more displacement ( I.e. Different stroke and bore..i believe a 84mm bore?), BUT the cylinder walls are ALOT thinner than a b18b1 or b18a1. The b18b/a have a 81.5mm bore and i think i shorter stroke than the b20. You can bore out the b18 to reach a higher displacment without having to worry about the stock sleeves( only to a certain size.) Some say b16 heads are better for whatever reasons, but i think its been proven that the p72 head flows better and gives better overall performance. I also am not 100% on these facts so read this:..
    http://forums.importatlanta.com/showthread.php?t=29785
    that will hold all your answers.
