Results 1 to 1 of 1
Thread: D-Powa
    A.K.A Felipe Gomez Negrodamus's Avatar
    Daaaaaaknessss
    Default D-Powa
    Drag strip:
    http://www.civictsi.com/Videos/Civic_Tsi_Hi.mpg
    "the music is sooooo 2003"
    Inside car 0-200km
    http://www.civictsi.com/Videos/Civic...sideCarRun.mpg
    Setup:
    Block:
    D16Z6
    Stock sleeves bored .020 over
    NewformZ blockguard
    ARP head studs
    Arias 9:1 pistons
    Eagle rods
    Stock crank
    Head:
    Ported D16Z6 head
    Manley stainless steel valves
    Zex valves springs
    Stock valves retainers
    Custom camshaft
    Skunk2 cam gear
    Stock head gasket
    Custom intake manifold
    Precision 680cc injectors
    Electronics:
    MSD 6AL
    MSD Blaster 2 coil
    MSD 2 step rev limiter
    Greddy turbo timer
    Greddy Profec B boost controller
    Chipped ECU running Uberdata
    GM 3 map sensor
    FJO wideband with gauge display
    Autometer gauges
    Induction:
    Mitsubishi TD05-20G turbo
    FMIC 30x11x3.5
    HKS SSBOV
    Tial 38mm external WG with 15psi spring
    Exhaust:
    Custom turbo manifold
    3" stainless steel downpipe
    3" stainless steel exhaust
    3" stainless steel Vibrant muffler
    Driveline:
    Protane total kit bushings
    Protane motor mounts kit
    Koni yellow shocks
    H&R race springs
    JimFab traction bars
    11lbs flywheel
    ClutchMaster stage 4 clutch
    92 Si tranny with 4th and 5th gears from a 91 Si tranny
    Quaife LSD
    Stock axles
    M&H 22 x 8 x 15 slicks
    Toyo RA-1 street tires
    weight about 2350lbs with me in racing form.
