Results 1 to 4 of 4
Thread: HID HELP
    Senior Member | IA Veteran Speedm0(\)key's Avatar
    Stone mountain GA
    Default HID HELP
    i've never fucked with HID's before.. the STi and the Z are the only cars i have ever had that came with HID's. my question and problem are the following:
    i slapped a D2cS bulb that is supposed to work with D2s and D2r in the 350z. however im supposed to use d2r's (have like a silver ribbon around bulb) and im not getting good visibility. actualy.. i can barely see streaks of hid blue on the road. ( i just did this half assed in GGPIS3's garage last night ), bulbs are 10,000k or whatever.. did i go to high in temp?.. is there a chance i didnt fit the bulb in right?.. do i need to realign the headlight?.. whats the deal here?
    any info/advice would be greatly appreciated.
    2004 Nissan 350z Trng
    2004 Subaru WRX STi
    solamente los putos te llegan en numeros
    Banana Hammock
    Cumming, GA
    I'm not too sure about the bulb compatibility, but be sure that bulb is seated correctly if anything. I don't think you should have to re-aim your lights though.
    also remember, a 10k bulb's output is considerably less than what you're probably used to ... so maybe that's it.
    to me 10k is way to high. i like 8k but yeah make sure that they sat in the right place.
    'Round These Parts
    d2s and d2r will fit in the same housing; however, d2r is strictly made for refelctor housings (Sti) not Projector hosuings (Evo)
    10,000Kelvin bulbs are trash when it comes to output- you'll actually experience a loss of output/visibility as you climb the kelvin scale.
    you need 4100, 4300k - 6,000k max
    Leisa and S. 4 Life NM?
