Results 1 to 18 of 18
Thread: Smoke out the exhaust
    Gwinnett-Grayson
    Default Smoke out the exhaust
    ok, so it doesnt happen at a constant pace or anything but when im exceparting and shift at an high RPM im told and have seen myself sometimes smoke come out of the exhaust. again, it doesnt happen all the time only in high RPMS, anyone know the reason this is happening?
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    DC5-R
    Gwinett
    what color is the smoke?
    AE86 biotch!!!
    Take a look at the name of this site.
    Could be many things. I need more details to be able to answer.
    AE86 DORIFTO
    Gwinnett-Grayson
    the color of the smoke is white....i mean i really cant give you anymore details then from what i have already given you.....
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    AE86 biotch!!!
    When it starts smoking does it make any strange noises? Does the car start driving strange in any way?
    AE86 DORIFTO
    Gwinnett-Grayson
    not really that i can tell...everything seems normal when i shift and what not and am driving, i can just kinda tell their is smoke commin out cuz i smell it it a little bit and people have seen it
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Jan 2005
    Columbus, Ga
    is it just when you shift?
    mine only has smoke carbon minoxide come out whne it shifts....im thinkin thats what yours in...
    what type of cat convertor do you have...stock?
    i know you love my swagger
    OG Black Delegation member
    RIP My Homie Elliot Sloan
    Gwinnett-Grayson
    yeah, but like i dont see smoke come out of it every time i shift its only when and if i shift at like high RPM's...yeah i think i have a stock one...i dont remember lol
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Jan 2005
    Columbus, Ga
    Quote Originally Posted by blacknightteg
    its probably just carbon minoxide, you either have a bad cat, no cat, or a hole in ya cat convertor( which either one aint that bad, your just polluting more and wont pass emissions if you attempt) as long as your not shootin oil out, your fine.
    shootin oil out your exhaust....blown head gasket
    Gwinnett-Grayson
    Quote Originally Posted by B16a2 Civic
    well see thats the thing, this has been goin on for a while, even before i had my emissions test and i passed that
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Jan 2005
    Columbus, Ga
    well, then its one of those things where you gotta be there to tell you exactly, as long as it nots black, your good
    more likely its your cat
    Gwinnett-Grayson
    lol, yeah...thanks for the insight tho....i mean its not really that much of a bothersome cuz im not like rappin the hell out of my car when it comes to shifting or anything, i just figured id find out wtf it was
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    White smoke isnt a fuel problem, its possibly a sign of coolant in the exhaust. You could possibly have a cracked head/blown head gasket. Sometimes when the head gasket goes it will produce a passage for the antifreeze to pass from the capillaries into the combustion chamber
    Black smoke is a fuel issue. I spray black smoke when I use nitrous and the bottle is almost empty, and before I had any tuning NA.
    Jan 2005
    Columbus, Ga
    i had the colors backwards LIRL
    Gwinnett-Grayson
    yeah but i mean like i said its not a constant thing only when im in high rpms. if it is a coolant problem could that because the engine is working harder or something so it makes the smoke come and be more appearant?
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Most any problem starts at higher RPM's then gradually starts affecting mid range RPM's , etc. Get it checked out for sure.
    Gwinnett-Grayson
    yeah, i will, i just dont understand it cuz its been happening for a good while, and from what i can tell no other major problems
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    oil chang
