Results 1 to 19 of 19
Thread: FS - Audio crap
    Default FS - Audio crap
    Brand new Rockford Fosgate amp model P3001. Asking $130
    Brand new Rockford Fosgate 10" p3 subwoofer. Asking $120
    Used Cadence Beast 12" sub. $75
    Brand new Rockford Fosgate 8" P2 subwoofer. Asking $40
    I can supply pics of anything
    Attached Thumbnails Attached Thumbnails -audio-jpg
    OMG IS THAT Mr.Wong? justwongit's Avatar
    pics?
    roflcopter V-Spec II
    Norcross
    Can I get power handling and specs on the P2, as well as pictures.
    Here and there Hulud's Avatar
    Omnipresent
    hey chris imma gonna call you tomorrow about the sub and amp, cause i need a better one
    Val for President
    IA MEMBER YokotaS13's Avatar
    saudi arabia
    will yuo ship the 8 to japan?
    justwongit - what did you need pics of?
    i will get you pics and specs of the p2 shortly. it's in my car and it is kinda hailing right now.
    i will ship to japan, you pay shipping of course.
    thats cool brian, just give me a call.
    pics of all
    A day late, a buck short BufordŽ's Avatar
    Apr 2003
    Starin' at the world through my rear-view.
    Pics of the amp, please. Oh, and is it 300 watts to 1 channel?
    My 2001 Acura 3.2CL Type-S
    Val for president!
    Yes, I would have voted for her.
    In loving memory of Valerie Antranikian.
    bad pics, but ya get the idea. the p2 8" sub is at my friends and i can't get it back until tomorrow.
    from fosgates sites..
    amp
    Number of Channels 1
    Rated Power 150 W x 1 @ 4 Ohms RMS
    300 W x 1 @ 2 Ohms RMS
    Total Power 300 Watts
    Bridgeable No
    Crossover Controls High-Pass (HP): 40-400Hz 12dB/octave Butterworth
    Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
    Tone Controls Bass: 0dB to +18dB @ 45Hz
    Signal Input Low level: 1 RCA pair
    Signal Output Low level: 1 RCA pair
    Power Input Connector Block
    Power Wire Gauge 4 AWG
    Speaker Output Connector Screw terminal barrier strip
    Speaker Wire Gauge 8 AWG to 18 AWG
    Heat Sink Type Cast aluminum
    Cooling Convection
    Remote Controls Punch Bass EQ (included with cable)
    Visual Indicators Power On
    Signal Level
    Thermal Status
    Speaker protection
    Circuit Topology Class Class-bd
    Frequency Response 20Hz to 20kHz +/- 0.5 dB
    Dimensions 2.4 x 11 x 11.7 (in)
    6.1 x 27.9 x 29.7 (cm)
    Weight 11.5 Lbs.
    (5.2 Kg.)
    10" p3
    Size 10"
    Impedance 2-Ohm x 2
    Power Handling 400 RMS
    800 Peak
    Motor Size 77 oz. double stacked
    Voice Coil Diameter 2.5" aluminum
    Speaker Connector Dual 8 AWG compression
    Mounting Depth 5.9375"
    Rec. Sealed Enclosure 0.65 cu. ft.
    18.4 liters
    Rec. Vented Enclosure 1.25 cu. ft.
    35.4 liters
    Tuning Frequency (vented) 40 Hz
    Weight 19.2 Lbs.
    (8.7 Kg.)
    8" p2
    Size 8"
    Impedance 4-Ohm
    Power Handling 200 RMS
    400 Peak
    Motor Size 30 oz. double stacked
    Voice Coil Diameter 2" aluminum
    Mounting Depth 4.0625"
    Rec. Sealed Enclosure 0.25 cu. ft.
    7.08 liters
    Rec. Vented Enclosure 0.65 cu. ft.
    18.4 liters
    Tuning Frequency (vented) 42 Hz
    Weight 8.25 Lbs.
    (3.7 Kg.)
    UNITED STATES MARINE jdm7thgen's Avatar
    canton / ball ground
    i will take the 8 p2 pm me and clear ur pm box its full. were u located?
    NorthSide
    cut a deal on the 8" p2 and amp?
    located in cartersville. my pms are clear.
    if the other deal falls through i would knock some off if you bought both the p2 and amp.
    Everything still available :/
    ttt
    up one more time
    Fuk Who U B!
    Northside B
    Check PM!
    saudi arabia
    ill give you 50 shipped WITH insurance to me
    93626
    still have this stuff
    Please post pictures of ALL your $50+ items on the first post. Thank you and good luck with your sale.
