Results 1 to 5 of 5
Thread: Installing Alarm
    Roswell, GA
    Default Installing Alarm
    So I got a cheap alarm (mainly for keyless entry) for my girls car, I'm tryin to install it, but need a bit of advice. The same color wires that go from the ignition, run through the kick panel, but hey are a different gauge, anybody know if they are stillt he same wire and i can splice them from inside the kickpanel, or do I need to go straight from the ignition, any QUICK help will be very greatfull.
    Its for a 1998 Ford Explorer
    2005 VW Jetta GLI
    FS: 96 200SX SE-R Parts, PM me for details
    MySpace
    Dec 2003
    Alpharetta
    get a multi meter before you try. and get them at the ignition harness. when you take the under dash down the harness will be partially covered by a gray plastic cover. just pull it off and throw it away. grab them all there.
    Vroom Vroom
    probably wont be if its a different gauge wire
    y tu mamá tambien!! Dave's Avatar
    Lawrenceville, GA
    YEAH... they probaly aren't... it just safer to do it of the ignition itself.
    Johns Creek
    They are definately not the same wires. Ford does not change guages on the ignition wires inside the interior of the vehicle. Tag to the harness wires near the ignition. If you have any questions of how to do it, have a professional (or someone more experienced) do it for you.
