Results 1 to 18 of 18
Thread: FS DB104 subs i got 4 of em
    (OO=[][]=OO) Dominic49's Avatar
    Default FS DB104 subs i got 3 of em $50 each
    FS DB104 subs x4 new in box $50 a piece OBO
    Polypropylene cone with a rigid ABS dustcap to stiffen the cone for greater mechanical stability and lower distortion.
    Marine Certified Polk db Series speakers are built tough to withstand the toughest environments so they are perfect for use in boats of all types. That's why Correct Craft offers Polk Audio speakers in their award-winning Nautiques ski and wakeboarding boats.
    Santoprene surround is impervious to extremes in temperature, humidity and exposure to sunlight for excellent long term reliability.
    Fire-retardant flat NOMEX® Spider allows extended linear motion while providing highly reliable mechanical and thermal stability.
    Double venting of the 4-layer Kapton Voice Coil Former, Cone/Coil Coupler and Pole Piece contribute to the high power handling and reliability of the db Series subs.
    As with all Polk Audio subwoofers, the voice coil alignment, motor and suspension were optimized using a state-of-the-art Klippel laser analyzer. The result is superior cone travel linearity for flatter response and lower distortion.
    <li>Driver Complement Woofer 1 - 10" Diameter (25.40cm)
    Dynamic Balance Polymer Composite dish cone Electrical Overall Frequency Response 28-200 Nominal Impedance 4 ohms Power Handling (continuous) 270 w Power Handling (peak) 540 w Efficiency 86 dB Voice Coil Diameter: Driver 2" (5.08cm) Driver Mounting Depth Top Mount 5-1/2" (13.97cm) Bottom Mount 6-1/4" (15.88cm) Cut-out Driver Cut-out Diameter 9-1/16" (23.02cm) Theile/Small Parameters Recommended Enclosure Sealed / Ported / Bandpass Resonant Frequency 37 Hz Qms 7.0 Qes 0.62 Qts 0.57 Vas 0.85 cu. ft. / 24.0 L Sd 54.25 sq. in. / 350 sq. cm. Xmax (linear) 0.3 inch / 7.5 mm Xmax (mechanical) 1.0 inch / 25.4 mm Le 1.85 mH
    ^ Has way toooo much pr0n v3rd1g0's Avatar
    Marietta/Lawrenceville
    pictures, price, use?
    No siggy as of right now
    Senior Member JASONBALL's Avatar
    columbus GA
    if you could show a actuall sub it would help. for all we know those boxes are empty not saying they are but you know. best to set a price or someone is gonna give you a price and you might think it is way to low. so generalize it for people.
    columbus GA
    were getting there now some pics
    thx for the help
    Woodstock
    How many watts are the 10s? I need one if they atleast 600
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    they push 270 rms each i think
    pm'd
    BUMP
    price lowered
    striaght up
    Woodstock
    where are you located I want a 10
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    Celica Crazed hoffman777's Avatar
    how many you got left
    3 left now I am in marietta near 92 and sandy plains
    show me the love?
    roflcopter V-Spec II
    Norcross
    bump and if you want a box for it I have a ten for sale that will fit them (I used to have a 10 inch polk momo in there)
    you still have these?
    ya
