Results 1 to 5 of 5
Thread: got a question 1990 eclipse gs trubo
    stockbridge
    Default got a question 1990 eclipse gs trubo
    I found a 90 eclipse gs turbo that the guy blew the motor in, he says the motor has no compression and i was wondering if someone knows about how much it would cost to rebuild the existing motor or to buy another motor to drop in its place.
    used motor 1300-1600
    your moms house
    or you can buy my entire car for that much and its a 1990 as well
    Alpharetta/Duluth
    I just did a 6-bolt shortblock with h-beam rods, forged pistons, machine work, and installed for about $3200 including labor.
    If your head is toast or the valves are bent then it would be extra.
    With a used engine it would be cheaper, but it would be a little iffy going with an old engine without at least freshening it up with bearings, rings and a new oil pump.
    You really need to figure out if the timing jumped or if the motor is just blown.
    If the timing jumped then you might get away with a freshen up and new valves. If the motor spun a bearing then a new crank would be in order if you ever plan on boosting hard.
    how much would that setup be with a head five star?
