Results 1 to 10 of 10
Thread: CD Player HELP!!!
    Honda/Acura Lover 93Lude's Avatar
    Tennessee
    Question CD Player HELP!!!
    Why would a cd player not turn on and when I hook up the Yellow to posative and black to negative spark and the cd player not turn on or anything??? When it sparks it is like a magnet and the harness wires almost stick to the battery....WHY???? Is the cd player fried? :confused:
    Life sucks and then you die, so rev it up and let it fly!
    FOR SALE 93 Prelude Si
    check your fuses
    Tennessee
    Quote Originally Posted by plv
    check your fuses
    I did the yellow wire had an in line fuse and i blew 13 15amp fuses so I cut it off and tried connecting it directly and it does what I said before!!!
    georgia
    sounds shorted out inside,and you need a yellow,red and a black wire hooked up to get the radio to come on.
    if your testing it on a battery just hook the red wire to the yellow wire and make sure your working with a good battery.
    make sure no wires are toucing each other like speaker wires.
    yes i am....
    Jan 2005
    Columbus, Ga
    also, check teh fuse on the inside the car, backup fuse outside the car and the cd player fuse, if it aint one of thosem ,ake sure the connectors you used to combine wires are tightned and the wires are connecting...if all fails, its the cd player
    i know you love my swagger
    OG Black Delegation member
    RIP My Homie Elliot Sloan
    Tennessee
    Quote Originally Posted by bodydropped
    Ok I did all of that and it still does the same just barley not as bad as befpre though....I think I did have speaker wires touching at first!!
    Tennessee
    Quote Originally Posted by B16a2 Civic
    I hooked it up to a bare battery,(not in any car)
    georgia
    did you fix it? i lost my front speaker output because of touching wires before.thats why they reccomend you unhook your battery before installing a stereo or amp. if the radio is still shorting out its proably toast.
    yes i am....
    Tennessee
    Now when I hook it up it does nothing at all.......
    georgia
    Quote Originally Posted by 93Lude
    its dead man.unless you blew the fuse on the back of the radio.
    yes i am....
