Results 1 to 14 of 14
Thread: Home Networking Question
    Default Home Networking Question
    Currently I have the following setup.
    Two desktops
    1: SONY VAIO P4 SYSTEM
    2: CUSTOM BUILT AMD X2 SYSTEM
    Both running above 2.5GHZ.
    PC number 2 acts as a makeshift server for now, since it soon will have approx. 1 Terabyte of hard drive space after I install more drives. Now both computers are wirelessly connected to the internet via a Netgear 108MBS router. Now my question is, I currently have PC number 2's hard drives accessable by PC number 1 via the desktop, however they are connected wirelessly. Therefore, transfer rates are pretty slow. Now, I bought a 10/100 switch today in hopes to connect them this way. Both have NIC cards that have standard CAT5 cables running into the switch, but the computers are having a tough time connecting in any way.
    Below is a screen shot of what PC number shows.
    And here is the switch that is automatically configured to work which show green lights on all ports that are connected.
    Please give me some help, so that I can transfer files across the switch at a higher rate, rather than wirelessly.
    IA KING
    you need to connect them directly into the switch to take advantage of transfer rates, i would suggest going w/ a 100/1000nic and switch for good transfer rates.
    Quote Originally Posted by admin
    thats what I have, but they arent connecting
    LNC FTW
    I'm up 'n Cummin'
    Unless you have a hardware or software bridge you ought to get rid of that bridge connection in your network connections page.
    Just click on the networking wizard button and follow the instructions.
    Shoot me a PM I am will answer it will exact instructions when I get home form work.
    EDIT: Something else you might want to try is disabling the wireless connections on both machines so that they are forced to use the NIC cards instead of the wireless. Computer are retarded and get confused when there is more than one way to connect to something. I learned that the hard way.
    IA KING
    ^ yes what he said, you shouldn't be using wireless and cat5 connected... disable your wireless cards. run static ip's, make sure both cards are configured correctly
    Woodstock
    i say you kill yourself and all your problems will go away...
    Val RIP
    my only rule in life
    Hampton, Ga
    set both computers up on the same workgroup
    BYAAAAAAAHHH!!! threehundred's Avatar
    22" off the ground
    the answer is simply what Admin and Duke said. He needs to disable wireless when doing transfers, especially if the wireless connections are set to connect automatically to the network. The computer doesn't know which connection to use, so it uses the one that was setup first.
    05 Chrysler 300 - Kitted on 22s
    06 Quad Cab Dodge Ram 1500
    Oct 2003
    and again...i agree it wat duke and admin says...
    slowpoke
    reset power on the switch/router after everything if reconfigured
    Get rid of XP Home.
    ^ Has way toooo much pr0n v3rd1g0's Avatar
    Marietta/Lawrenceville
    haha if i could +1 you i would :-D
    No siggy as of right now
    LNC FTW
    I'm up 'n Cummin'
    Quote Originally Posted by Trey
    Get rid of XP Home.
    that is a very good networking tip.
    all in favor of *nix systems say "I"
    I
