Results 1 to 11 of 11
Thread: clocking the turbo
    georgia
    Default clocking the turbo
    i just got my turbo today. i noticed that the oil drain appears to be on top of the turbo when its bolted to the manifold. can i safely remove the 4 bolts on the compessor housing and rotate it to the correct position?
    yes i am....
    georgia
    why yes mike,you can loosen those bolts and rotate the housing safely into the right position.
    yes i am....
    georgia
    thank you sir
    yes i am....
    georgia
    no problem
    yes i am....
    Daytona Beach
    what the second idiot said!
    georgia
    Quote Originally Posted by toojdm
    so you agree? i did a little more looking around and i think it can be done with out throwing off the balance of the turbo,thats my only concern. its nice talkin to someone other than myself.thank you
    yes i am....
    Certified Gearhead miro_gt's Avatar
    yes you can
    Certified Gearhead never2loud's Avatar
    go for it
    Drifter/Kneedragger
    Buford, GA, USA
    don't need to remove the bolts, just loosen them and rotate everything to where it needs to be and re-tighten. clocking has nothing to do with the balance of the turbo, you are merely rotating the housings around the center section.
    sounds like it was ment to be a top mount, but yeah loosen those bolts and clock that bitch. good luck i destroyed 5 wrenches rebuilding my t28.
    georgia
    thanks for the info.so i can rotate the compressor side too? it looks like that has to be moved a little too.
    yes i am....
