Thread: Wheel hippidy Hop Problems ! ! ! !
    The Squirrel Master Mpatient's Avatar
    Default Wheel hippidy Hop Problems ! ! ! !
    well I've read on here before about someone who had wheel hop problems and well...
    Now I'm in the same boat. I had just insatlled a nwe clutch and couldn't really stress it, but now that it is broke in my launchs have very bad wheel hop all the way through third. I know and Lsd will help with this, but I've read somewhere before that my tires might be to small 215/40/zr17, and also what suspension mods will help with this???
    any help would be most appreciated.
    specv's have disgusting wheel hop, but new motor mounts, or inserts work miracles. it might help, might not, but i just thought i'd throw the idea out.
    Quote Originally Posted by fox
    preciate it bro.
    A corolla can kick yo ass
    Softer suspension?
    :confused: :confused: :confused: :confused: :confused: :confused:
    ALL CAPS JITB's Avatar
    solid motor mounts will help, and if preludes have bobble struts, upgrade it also.
    IA MEMBER YokotaS13's Avatar
    saudi arabia
    motor mounts are a must if you have wheel hop, im having to upgrade the motor mounts, diff bushings, nad suspension bushings in my FD to get rid of it
    A lot of peeps are saying to upgrade my mounts so that will be on my to do list...
    thakns for the info peeps.
    Switch to Urethane Solid Motor mounts. Hasport or AVID will work. Nopi carries AVID so try those.
    Traction bars are a plus, although expensive and im not sure they make them for your year model. Also stiffer suspension , better stuts can help. id do the motor mounts first
