Results 1 to 2 of 2
Thread: need help ASAP!
    lilburn
    Default need help ASAP!
    Im on vacation right now in daytona and last nite i noticed that i had smoke coming out of my air vents and i smelled plastic burning. I popped my hood and my fog lights wires were melting b/c they weren't wired correctly (no ground). Well when i was slowing down to a stop, my car shut off at about 5 mph when i put it in nuetral. I took out all the wiring for foglights and tried to start my car but it wouldnt start. It turns over but it won't start. I know its not the battery and i dont think theres a problem with fuel. Im about to check the spark plugs and fuses and distributor but if its not that then i have no idea what it could be and i dont have $$$ for honda to fuck around for a few hours and charge me $300 for an hour of work. Does anyone have any suggestions of what else i should check on it and what it could possibly be? Any help is appreciated. I have to drive 6 hours back home in two days so i need it fixed asap. thanx
    JJSPEC Racing
    check fuses....can you hear the fuel pump turn on when you turn the key to the on position? check spark out of each wire, if its turning over its not a battery/alternator problem, past that i cant think of much right now
    -2001 Lexus IS300
