Results 1 to 15 of 15
Thread: Dodge caliber
    Senior Member JASONBALL's Avatar
    columbus GA
    Default Dodge caliber
    Well me the wife test drove the caliver today. drives very well can't even fell it shift. it was just he 2.0 engine. very spacious inside. a couple of stupid little gadgets here and there. rear seat recline. good space. 4 out of 5 review from me.
    been so long
    Alpharetta
    You should see the SRT-4 Caliber its pretty nice. I like how the cup holders light up and there is a cooler in the car as well lol.
    columbus GA
    where is the info on the srt-4 caliber. I couldn't not collect any info from the dealership on this only the RT AWD
    I drive a dodge stratus 98strat's Avatar
    Norcross
    High-caliber Performance: With 300 Horsepower, All-new 2007 Dodge Caliber SRT4 to Dominate Sport-compact Market
    * Tire-smoking 300 horsepower — 85 more than the original Dodge SRT4 — and 260 lb.-ft. of torque
    * 0-60 mph in less than 6 seconds
    * All-around performance of a true "tuner car" right from the manufacturer
    * Benchmark performance at the best price
    Chicago, Feb 8, 2006 -
    Chrysler Group's Street and Racing Technology (SRT) group will take the SRT4 reputation to new heights with the introduction of the all-new, 300-horsepower 2007 Dodge Caliber SRT4.
    "The all-new 2007 Dodge Caliber SRT4 achieves the SRT mission of offering benchmark performance for the best price," said George Murphy, Senior Vice President – Global Marketing, Chrysler Group. "With 300 horsepower under the hood, the Dodge Caliber SRT4 will dominate the sport-compact market."
    With true tuner performance right out of the box and a great price, enthusiasts immediately took to the original SRT4, which was introduced in 2003 at the Los Angeles Auto Show. In the 2003-2005 model years, more than 25,000 Dodge SRT4s were sold.
    "We couldn’t wait to infuse Dodge Caliber with the SRT formula," said Murphy. "The all-new 2007 Dodge Caliber SRT4 delivers a strong dose of all-around performance while delivering more than 28 miles per gallon on the highway. Our new SRT pocket rocket is going to be a hoot to drive."
    Since its inception in 2002, SRT has introduced 12 extreme-performance vehicles, including the Viper-powered Dodge Ram SRT10 regular cab and Quad Cab TM , Chrysler Crossfire SRT6 Coupe and Roadster, Chrysler 300C SRT8, Dodge Magnum SRT8, Dodge Charger SRT8, Dodge Viper SRT10 Convertible and Coupe and Jeep® Grand Cherokee SRT8.
    Every SRT vehicle showcases five key aspects: exterior styling that resonates with the brand image; race-inspired interiors; world-class ride and handling characteristics across a dynamic range; benchmark braking; and standout powertrain.
    The all-new 2007 Dodge Caliber SRT4's formula begins with powertrain, essentially explained by four numbers: 85, 125, 300 and 260. The 85 is how much more horsepower than the original Dodge SRT4 is available, which results in 125 horsepower per liter for a total of 300 horsepower. The final number is 260, as in 260 lb.-ft. of tire-smoking, push-back-in-your-seat torque.
    Standout Powertrain
    The all-new 2007 Dodge Caliber SRT4 is capable of a 0-60 mph time in under six seconds. How is that possible?
    The all-new 2007 Dodge Caliber gets its motivation from an all-new "World Engine" produced at the Global Engine Manufacturing Alliance (GEMA) facility in Dundee, Mich. The World Engine is a family of small fuel- and emissions-efficient aluminum four-cylinder gasoline engines co-developed by DaimlerChrysler's Chrysler Group, Hyundai Motor Company and Mitsubishi Motors Corporation.
    "The all-new 2.4-liter turbocharged World Engine delivers a level of power you'd expect from a V-8," said Pete Gladysz, Senior Manager – Powertrain, SRT. "With the engine in the all-new 2007 Dodge Caliber SRT4, we were able to take advantage of tried-and-true performance improvements, such as increased cylinder-head flow and higher compression ratio, as well as newer technologies such as Variable Valve Timing (VVT)."
    To achieve its high-performance Dodge Caliber SRT4 configuration, the aluminum 2.4-liter World Engine block is specially machined for increased water and oil flow. Unique cast pistons travel within iron cylinder liners, and are cooled by oil squirters and affixed to forged connecting rods for high-revving reliability.
    Tri-metal bearings are used for the connecting rods and crankshaft for high-performance durability. A unique oil pump/balance shaft module keeps the reciprocating assembly well-lubricated and running smoothly. An external cooler keeps oil temperatures within a safe range.
    The aluminum cylinder heads are also a World Engine casting equipped with unique high-temperature exhaust valves. VVT uses computer mapping to open and close intake and exhaust valves at optimal points for efficient combustion and flow. The camshaft and micro-alloy steel crankshaft, shared with the non-turbocharged 2.4-liter World Engine, are fully capable of high-horsepower loads.
    Free-flow induction begins with an all-new air cleaner assembly that draws through an opening in a front crossmember for proximity to cool air. The air is then compressed in a TD04 turbocharger specially configured for the engine's inlet and outlet packaging requirements, and sent through an intercooler to a 57 mm throttle body.
    Fuel is provided by a high-flow pump feeding injectors developed specifically for the 2007 Dodge Caliber SRT4. An all-new engine management system designed by Siemens — the Global Powertrain Engine Controller — keeps the powerplant running at maximum efficiency and power.
    On the exhaust side, spent gases exit through a free-flow system that features two catalytic converters — one immediately downstream from the turbo, and another further along the 3-inch single-pipe exhaust system. Using two catalytic converters in this way provides significantly better "light-off" for decreased emissions. As with the previous-generation Dodge SRT4, the exhaust is tuned for maximum performance while meeting federal noise regulations.
    Power is transferred through a dual-mass flywheel to the six-speed manual transmission. The dual-mass flywheel consists of two flywheels sandwiching internal springs that are specially tuned to reduce noise and vibration. The GF DMT-6 six-speed transmission, equipped with a limited-slip differential for uniform side-to-side power transfer, is capable of handling up to 300 lb.-ft. of torque.
    Torque is sent to the Dodge Caliber SRT4's wheels through equal-length halfshafts sourced from Chrysler Group mid-size cars for their larger size and power-handling capability.
    Functional, Performance-oriented Exterior Design
    Because there is only one chance to make a first impression, the all-new 2007 Dodge Caliber SRT4 makes the most of it with muscular exterior styling.
    "From the very first sketches of the all-new 2007 Dodge Caliber SRT4, we wanted an aggressive, SRT-signature look," said Trevor Creed, Senior Vice President – Design. "For example, because the intercooler is positioned so high behind the front grille, we moved the fascia slightly forward and extended the walls of the grille. The result is a much more aggressive look than the standard Dodge Caliber."
    An all-new front fascia below the signature Dodge crosshair grille incorporates functional performance features including ducts that direct air to cool the brakes and a wide center inlet that provides air flow to the radiator. Fog lamps are also set into the fascia, alongside brake ducts. The 2007 Dodge Caliber SRT4's hood incorporates a functional scoop that brings cooling air into the engine compartment and a pair of extractors that exhaust hot air.
    "Exterior design that works as well as it looks is a requirement for all SRT vehicles," said Creed. "The hood design had to include the functionality of bringing cool air in and getting hot air out."
    The lowest portion of the 2007 Dodge Caliber SRT4's fascia, which acts as an air dam to direct air around the front of the vehicle, wraps around to visually integrate with the radiused wheel wells and lower side-sill moldings.
    The rear fascia continues the muscular, functional character of SRT vehicles, with lower vertical strakes that direct underbody air flow out the back of the vehicle, contributing to more stability at speed. A single, 3.5-inch exhaust tip exits from the right side of the fascia.
    Aerodynamic efficiency is also aided by an integrated spoiler above the rear glass, which incorporates the Center High-mounted Stop Light (CHMSL). This spoiler, which is nearly 60 percent larger than that on the standard Dodge Caliber, is tuned for smoother air flow and downforce while maximizing the rear view.
    Four exterior colors will be available on the all-new 2007 Dodge Caliber SRT4: Brilliant Black, Sunburst Orange, Bright Silver and Inferno Red.
    Race-inspired Interior Appointments
    In the "business office" of the all-new 2007 Dodge Caliber SRT4, a new interpretation of traditional SRT themes is carried out.
    "The 2007 Dodge Caliber interior is unique with sophisticated and contemporary appointments," said Creed. "When we enhanced it with SRT cues, we followed design themes that had been successful with the previous Dodge SRT4, including the graphic design of the instruments, separate boost gauge, and silver finish on the center stack and interior trim.
    "Overall, our strategy was to infuse the interior with performance-oriented enhancements to complement the Dodge Caliber SRT4's aggressive exterior," Creed added.
    Unique SRT touches include sport seating with aggressive bolstering and performance fabric inserts to hold occupants during spirited driving, and a leather-wrapped steering wheel with a "carbon fiber" pattern on the upper portion. The seats, steering wheel and leather shift boot feature contrasting stitching. Also unique to the 2007 Dodge Caliber SRT4 is an "alloy silver" finish on the instrument panel and shift bezel, and bright aluminum pedal pads that feature rubber studs for enhanced grip.
    The center-stack-mounted shifter includes a lift ring to engage reverse, unique to the Dodge Caliber SRT4, as well as a leather-finished shift knob.
    The instrument panel features three gauge "tunnels" outfitted with performance-oriented instrumentation, including a tachometer, 200-mph speedometer and water temperature and fuel gauges. A turbocharger boost gauge is located on the left side of the instrument panel.
    For the enjoyment of audiophiles, the 2007 Dodge Caliber SRT4 is equipped with a standard AM-FM radio with a multi-disc CD changer control. An available SRT/Kicker high-performance audio system includes 13 speakers in seven locations, powered by a 322-watt amplifier and 100-watt subwoofer.
    Two communication options are available on the 2007 Dodge Caliber SRT4: UConnect TM Hands-free Communication System and SIRIUS Satellite Radio.
    The UConnect system uses Bluetooth® technology to provide hands-free wireless communication between the customer's compatible cellular telephone and the vehicle's outboard receiver. Bluetooth is a short-range wireless networking technology that is used to connect two or more devices together.
    SIRIUS provides 2007 Dodge Caliber SRT4 customers with more than 120 streams of the best music, entertainment and information, coast to coast. SIRIUS channels include 100 percent commercial-free music, the most play-by-play sports, world-class news, as well as talk, comedy, women's, family and kids' programming, traffic and weather.
    The interior of the 2007 Dodge Caliber SRT4 is offered in Dark/Light Slate Gray.
    World-class Ride and Handling
    Another hallmark of SRT's balanced approach to performance is ride and handling characteristics that make a smooth transition from street to track.
    The all-new 2007 Dodge Caliber SRT4 rides on SRT-unique 19-inch cast aluminum wheels with 225/45R19 W-rated Goodyear tires. Wheel hubs and bearings on all four corners are adapted from Chrysler Group mid-size cars for strength.
    Upgrades to the standard 2007 Dodge Caliber's MacPherson strut front suspension include new suspension knuckles and tuned dampers with revised spring rates. Unique front and rear sway bars keep body roll to a minimum during hard cornering.
    The Electronic Stability Program (ESP) is uniquely calibrated for the 2007 Dodge Caliber SRT4 to provide excellent directional stability in all driving modes. In addition, stability is enhanced with a ride height one-half inch lower than the standard 2007 Dodge Caliber.
    Rack-and-pinion power steering is tuned to produce easier low-speed maneuvering, without compromising performance at speed. The overall steering ratio is 18.0:1.
    Benchmark Braking
    Benchmark braking is another ingredient in SRT's performance recipe.
    Norcross
    Although it's a compact car, the 2007 Dodge Caliber SRT4 benefits from braking-system components designed for much larger, heavier cars. For example, front brake calipers were sourced from a premium brake system developed for the Chrysler 300, Dodge Magnum and Dodge Charger, while rear calipers were sourced from Chrysler Group mid-size cars. However, all are painted in signature Dodge SRT red. Vented brake rotors for the 2007 Dodge Caliber SRT4 are 340 x 28 mm in front and 302 x 10 mm in the rear.
    The Anti-lock Braking System (ABS) was uniquely calibrated for the all-new 2007 Dodge Caliber SRT4's performance to maintain directional stability without wheel lockup.
    2007 Dodge Caliber SRT4 Safety and Security Features
    Following are safety and security features in the all-new 2007 Dodge Caliber SRT4:
    * Advanced Multi-stage Air Bags: Offers enhanced protection for a range of occupants and is designed to identify the size of an occupant in the front passenger seat based primarily on weight
    * Anti-lock Braking System: Equipped with electronic sensors that help prevent wheel lockup, the ABS system offers improved steering control under extreme braking and/or slippery conditions
    * Auto-reverse Sun Roof: An advanced sensing system that automatically engages and reverses the sun roof (to the open position)
    * BeltAlert: This feature sounds a periodic chime to alert the driver and all occupants to fasten their seat belts
    * Brake Assist: The vehicle senses a panic brake condition and applies maximum braking power, providing the shortest possible stopping distance
    * Brake/Park Interlock: Prevents an automatic transmission or transaxle from being shifted out of Park unless the brake pedal is applied
    * Constant Force Retractors (CFR): A mechanical device in each front seat belt is designed to mitigate the force of a seat belt according to the load or force exerted on it. CFRs are engineered to force-limit the belt system and gradually release seat-belt webbing in a controlled manner during a severe impact
    * Crumple Zones: An area of the vehicle that is designed to compress during an accident to absorb energy from an impact, preventing transfer of that energy to occupants
    * Electronic Stability Program (ESP): Feature aids the driver in maintaining vehicle directional stability, providing oversteer and understeer control to maintain vehicle behavior
    * Energy-absorbing Steering Column: Steering column contains two hydroformed coaxial tubes that move relative to each other, which allows the column to move forward and provide more energy absorption during an impact
    * Enhanced Accident Response System (EARS): In the event of an impact, this system makes it easier for emergency personnel to see and access occupants by automatically turning on interior lighting and unlocking doors after air bag deployment. The system also shuts off the flow of fuel to the engine
    * Height-adjustable Seat Belts: Allows passengers to lift and lower the shoulder belt to a comfortable level. Encourages seat belt usage by offering a more comfortable fit
    * HomeLink® Universal Home Security System Transceiver: HomeLink can store three separate radio-frequency codes to operate garage door openers, security gates, security lighting and other radio-controlled devices
    * Inflatable Knee Blocker: The inflatable knee blocker is an air bag that deploys whenever the driver's primary air bag deploys, helping position the driver relative to the primary air bag
    * Interior Head-impact Protection: Interior pillars above the belt line, instrument panel, windshield and rear window headers, roof and side rail structures, and shoulder-belt turning loops are specifically designed to limit head-impact forces
    * Knee Bolsters: The steering column, lower instrument panel and the glove-box door are reinforced to protect unbelted occupants during frontal impacts. They both restrain and position the occupant properly and enable air bags to work effectively
    * Lower Anchors and Tethers for Children (LATCH): This system helps ease the installation of compatible aftermarket child seats
    * Occupant Classification System (OCS): The OCS measures the conditions for activation or deactivation of the front passenger-side air bag based upon the weight of the occupant
    * Octagonal Frame-rail Tips: Octagonal tips are designed to collapse rearward in a controlled manner during a frontal or offset front impact
    * ParkSense Rear Back-up System: Assists with detecting stationary objects when driving at low speeds in Reverse. This system consists of visible (lights when the driver looks at the inside rearview mirror) and audible warnings
    * Power-adjustable Pedals: Allows brake, accelerator and clutch pedals to move toward or away from the driver. This helps the driver achieve a safe and comfortable seating position for improved vehicle control
    * Remote Keyless Entry: The remote keyless entry locks and unlocks doors, and turns on interior lamps. If the vehicle is equipped with a vehicle-theft security alarm, the remote also arms and disarms that system
    * Seat-belt Pretensioners: During a collision, impact sensors initiate front seat belt pretensioners to immediately remove slack from seat belts, which reduces the forward movement of an occupant's head and torso
    * Sentry Key® Engine Immobilizer: This utilizes an engine key that has an embedded transponder with a pre-programmed security key code. When the key is inserted into the ignition, the controller sends a random number to the transponder and the engine is allowed to start. If the correct key is not used, the engine will shut off after only a few seconds
    * SmartBeam® Headlamps: Intelligent headlamp system that adjusts to ambient light and oncoming traffic to deliver maximum lighting
    * Supplemental Side-curtain Air Bags: Available side-curtain air bags extend protection to front- and rear-seat outboard occupants. Each side air bag has its own impact sensor in order to autonomously trigger the air bag on the side where the side impact occurs
    * Tire Pressure Monitoring (TPM): This advanced system monitors tire pressure and alerts the driver to improper tire pressure conditions. Low pressure on any tire illuminates the amber warning indicator in the instrument cluster
    Street- and Track-tested Quality
    The all-new 2007 Dodge Caliber SRT4 was designed and engineered under the Chrysler Development System (CDS), the comprehensive, coordinated and disciplined product-creation process that improves quality and speed-to-market while reducing costs and encouraging practical innovation in new vehicles.
    CDS emphasizes systems engineering, design and up-front planning to avoid time-consuming and costly trial and error, or changes during the later phases of the product development cycle. With CDS, all product and process planning is completed and fully integrated before production tooling begins.
    2007 Dodge Caliber SRT4 development also encompasses actual conditions, both on the street and on the race track.
    To simulate real-world conditions, the 2007 Dodge Caliber SRT4 will have logged nearly 2 million customer-equivalent road miles by the time vehicles begin appearing in dealerships.
    To ensure its track-ready character, extensive durability testing of the Dodge Caliber SRT4 will take place at Firebird Raceway in Phoenix; Texas Motorsports Ranch in Ft. Worth, Texas; and Nelson Ledges in Garrettsville, Ohio.
    QUOTE
    Simon Elliott, Managing Director of Chrysler Group said: "The SRT-4 has been developed by Chrysler Group’s ‘Street Race Technology’ performance division. All SRT vehicles feature unique exterior details, lowered sports suspension, sports interior and a powerful engine - the all-new 2.4-litre turbocharged engine boasts a tyre-smoking 300 horsepower to deliver a level of power you’d expect from a V8!"
    The SRT-4 is a performance version of the Dodge Caliber and offers 260 lb. ft. of torque from a 2.4-litre turbocharged engine to reach 0-60 mph in less than 6 seconds.
    QUOTE(Chrysler Group)
    Just a month after the Dodge Caliber wowed the auto show crowd in Detroit, a high-performance version of the replacement for the Dodge Neon makes its debut at the Chicago Auto Show--the Dodge Caliber SRT4.
    SRT4 project team leader John Cathcart discusses just how powerful this souped-up version of the Caliber is and how it got there...
    What turns a Dodge Caliber into a Dodge Caliber SRT4?
    "The first thing is horsepower. It all starts with the engine. We'll be upping the output to 300 horsepower, 260 footpounds of torque. That's always the prime ingredient of an SRT vehicle. It has to go fast. We of course, balance the approach. It has to go fast, stop fast, turn well, and turn heads. So we take that approach to all areas of the car. We're putting an enhanced braking system on the car as well. We always look for parts we can use from the corporate parts bin. SRT is a small organization. We are investment constrained typically as well as always after offering the best price possible to the consumer as well. The brakes, for example, we took from the Chrysler 300C. We take brakes from a 5,000 pound car and put them on a 3,000 pound car and the car stops real well. We've got performance acceleration, performance braking, now we also want the car to also turn well. So we need to have a little lower suspension. We were able to lower suspension by a half-inch on the car. We will retune the shocks and sway bars as well. But the prime ingredient of the car's handling ability will be the lower CG (center of gravity).
    Tires are also very carefully selected for an SRT product. We do have a couple of good tire offerings: an all-season tire and then a higher performance three-season tire. All are capable of the 150 mph top speed of the car.
    We have an extensive appearance treatment for this car. A new hood, a new fascia. Actually the cut line between the hood and the fascia had to change for the SRT4 in order to package the intercooler. We do bring the body sides down a little bit for better aerodynamics with lower side skirts, and a different rear fascia as well which offers diffuser veins for increased rear down force and better directional stability, better yaw stability in high speeds.
    We think we accomplished all the primary functions of the SRT vehicle with the Caliber SRT4 as well."
    How was the World Engine altered?
    "The World Engine does offer a pretty good platform for the customization SRT did to the engine. Similar to the Neon SRT4, we start out by turbocharging the engine. We crank up the cylinder pressures, put a turbo on, make sure we're providing a lot of fresh air into the turbocharger inlet, thus we have a reduced restriction inlet system, and then good cold air at pressure to the cylinders via the turbocharger and the intercooler system. That's really the heart of what makes the Caliber SRT4 an SRT from an engine standpoint."
    Bigger brakes:
    "The brakes are a Bosch system brake, as for the Chrysler 300C. The rotor diameter is 13 and change on the front. The pistons I believe are 58 mm. pistons on the front calipers."
    Transmission choices:
    "The Caliber SRT4 has a unique transmission developed specifically for that vehicle. Six-speed manual is only available in the SRT4 version of the Caliber. The vehicle performance is so tuned around the manual transmission and the gearing and top speed capabilities of that transmission, we really can't offer a different trans in the car and still maintain the level of SRT performance."
    Appearance features:
    "Seating is another SRT core element. We have a car capable of high lateral G loadings, stopping, accelerating quick. We need to make sure the driver and front seat passenger are held in place. We have very aggressive thigh and torso bolster and non-slip suede surface area seating. We have a seat that will cradle the occupant, hold them for aggressive driving maneuvers, and also provide a fair level of support at all times. Beyond the seats we do have a unique color scheme for the carpet and the interior trim. It darkens it up a little bit to give it a more performance look. Also, we have an IP that's unique in that we've got a boost gauge that's integrated with the IP. It's not integrated into the dials, it's actually separate were a cubbie bin would be on the left side of the driver. We have added in that spot a uniquely tooled boost gauge so you're able to see what the engine output is or the boost output is.
    The seats will have an embroidered logo in the seat back.
    columbus GA
    thanks for the info now I'm gonna print this off and throw it in the salesmans face. becuae I asked him about his package today. he said there is no such thing. i thought there was.
    good is dumb boosted1jz's Avatar
    alpharetta ga
    i will be 100% honest with you when i say i HATE the way that transmission feels.... it constantly sounds like the trans is slipping.... almost like some1 who doesnt know how to drive a clutch and is just riding it out really bad....
    other than that i like the style of the car
    ps i work 4 dodge so i get to play with all the cool toys 1st LOL
    If You Aint Blowin You Aint Goin!!!
    "So, Lone Star. Now you see that evil will always triumph...because good is dumb."
    columbus GA
    yeah the tranny sounds like it is whinning out all the way but it so smooth between shift points think. what dogde do you work at.
    2.0TRawr ironchef's Avatar
    Damn so the srt 4 caliber is already out and available for a test drive?
    alpharetta ga
    i work for atlanta dodge inside the 285 loop on peachtree industrial
    been so long
    Alpharetta
    BLA. I work for Palmer Dodge we are better. Just kidding Chris I love ya.
    A.K.A Felipe Gomez Negrodamus's Avatar
    Daaaaaaknessss
    ehhhh all it is a uglier evo x
    columbus GA
    no the srt-4 version is not availible yet to test drive.
    columbus GA
    sorry for the post then post but the srt-4 is comming out on late availibility.
    Verbing weirds language Gaspeedracer's Avatar
    Dallas Ga
    so that means that neon srt4 is going to be outta production and the caliber takin its place? If so that could be a good thing and a bad thing
    Chuck Norris and Mr. T walked into a bar. The bar was instantly destroyed, as that level of awesome cannot be contained in one building
